Wiper spindles
Finally got round to getting the wiper spindles on the G changed today. As I had to buy the complete assembly for the 463, I decided to remove the dash to change the whole lot which turned out to be a lot easier than I expected. Rather than excessive wear the culprit turned out to be one spindle that had seized solid and slackened the securing nut off so that water could pour in. Have now given the front a thorough soaking with the hose and no more leaks so the carpets can go back in now.
Many thanks to Gav for sorting me out with the correct part numbers and dealer contacts.
Next job is to change the front seats.....
Dougie
Hi Dougie
Glad you got sorted and was an easy ish job.
Which dealer did you get it from in the end and was it a good experience?
I am about to do these on my 463, could you talk through the basics of how to get to them. The easiest way to remove dash? I was just going to remove intsrument panel and glove box.
Any help welcome!
Hello Dougie,
You just need to remove the glove box and instrument panel to this job.
Check the enclosed link for instructions: http://fourbyfourclub.com/Manuals/W460WipersInstallation1.pdf
I got them from John Weir in Perth. The parts advisor was very helpful and seemed to know what he was talking about although he refused to discuss part numbers with me. They took a couple of days to arrive and he posted them out at cost which is a lot cheaper than me driving down to collect them so all good.
