What's this?
Easy for some of you...
Seems to me - this part might be past it's best?
I'd like to replace it - I'd like to know what it is called so I can get the local chap to order it.
This is a brace behind the rear n/s wheel, 1990's LWB G
I'd like to make sure they have the part before it goes in for it's next service.
Thanks to anyone who takes the time to help me out here...
The brace may be part number: A460 882 01 07 titled Stiffening. There should be one on the other side as well.
Check with the dealer before committing to buy. I have selected this part based on a 280GE LWB as I don't have details of your
vehicle. If the part is very expensive, it could be easily fabricated by your mechanic.
Hi known as a stiffenerand about £12 from merc agent
On EPC it is a stiffening fend , they are sided tho part number 460 882 01 07, and 460 882 02 07, some one with more knowledge will tell me which is drivers and passengers side were £7.40 +vat in October last year, without them backwings are a bit flexible....
Pretty much the same on all the SWB LWB Station Wagens 460 / 463
Left A460 882 01 07
Right A460 882 02 07
£7.60 Each + vat MB Germany
Standard 6mm Nuts, Bolts and Washers to fix then either end
The left one...
You have a PM
Yup. That's it sure enough.
Isn't Google brilliant!
I just put in that part number - and Google immediately returned that the part is usually rusted in half! Amazing!...
Thanks very much. I now know what "it's called", so can at least relate to the service chap...
