What temperature ?
Having just got G back after Head Gasket being done I've been monitoring Temp. Gauge sits at around 60 degrees when cruising 50 - 70mph. Outside Temp. Is 1 - 3 degrees. Seems a bit low to me.
Would be interesting to know what other owners Temp's are.
I put a blanking plate across by radiator in the depths of winter as it can struggle to warm up
Hello Marko,
Sorry for a late response from me, my router failed and only to-day had I received my replacement, hence been off line.
Yes, your temperature is low and I suspect the thermostat. Having had a head job done, I would have expected the thermostat to be renewed as a matter of course - shows poor practice if this has not been done.
Your temperature should be sitting on 85 degrees. The needle to be sitting on the top half of the digit '8' of 80.
i 2nd pistonhead on that.
my G300 sits on the 80 degrees line all day...
rgds hus
I think that there is nothing wrong with your thermostat, check it out on a few hill climbs but if external temp is hovering around zero your indicated temerature is fine. Huss is in Cyprus lucky bloke where it's a we bit warmer than here.
=D
well said prwales. i would still check the thermostat....just incase..
rgds hus
Hi Marko
Very easy DIY, 15 minutes tops
PS did you ever sort your ABS?
Part Number A102 200 19 15 comes with the "O" ring seal.
3 x 6mm thread (M10 socket) bolts, early original housing had M6 flat washers, later original or replacement housing had M6 spring washers.
I think yours should have the later type fitted, usually you can tell as the later has an M8 thread screw blank in the top
92 degree opening temperature.
IMHO always use the genuine stat, can't quite believe a garage has replaced the head gasket and not changed the stat as a matter of good practice? I always believed it was.....
Hope that helps.
Dont think so...
Sounds a bit strange...dont think they are related and sounds like you have had 2 faults.
The hot / cold is controlled by a cable from memory so that could have come adrift or the valve it operates could be faulty?
Assume you have the stat in the right way around but cant see it being that anyway?
Not Air Con is it?
Hi Marko
463 type Hot / Cold Heater Valve is part number A463 830 00 84 and are £97.50 + vat and MB Germany have stock
Thanks for replies. I think thermosat is fine just a wee bit lower than i thought it would be.
