What size brake pipe on a 460
Wed, 19/06/2013 - 17:12
I'm refurbishing my brakes, what size pipe goes from the brake hose to the calipers ?
Any ideas
Thu, 20/06/2013 - 13:09
#2
Re: What size brake pipe on a 460
4.75mm is used on every car I have ever dealt with .. as an ex brake testing engineer for Girlings.
Use Cupro-Nickel (Kuniform) if you can .. rust proof and vibration proof.. Copper can work harden with vibration and crack if not secured properly.
Thu, 20/06/2013 - 16:09
#3
Brake pipes are of a standard 3/16th inch or 4.75mm but my imperial to metric conversion comes out at 4.7625 mm.
