W460 Headlamp Washers
Mon, 11/03/2013 - 12:47
Has anyone found an economical way to repair the headlamp washer jets on a W460?
Both mine are broken where the rubber pipe connects to the plastic jet housing, i.e. the plastic inlet has snapped off both of them.
I found some at starpartz but at £25 a pop unfortunately
Now got a couple (thanks Peter) didn't realise that I only needed the plastic connector, not sure if this is available as a separate part thought.
