tool kit and jack
Mine is in a cubby hole under the driver's seat.
Ian
jack maybe under the bonnet on the inner wing by the clip for the bonnet stay in a very neat bespoke holder with leather strap /tool roll under the dash on the passenger side held up by two rubber straps .
If you do want a bottle jack, cheaper ones than Mercedes Benz jacks can be bought to replace yours.
The Hi-Lift jack is also fine; not having used one I do not know of the mounting points.
Hi Darragh,
Ref your question about fiiting your highlift to the back door: I haven't had a lot of success with my backdoor having put a bike rack on it with only 2 (lightweight) bikes. Lots of extra vibrations working the mounting plate for the wheel lose, drumming of the back door, etc. It might be better for you to fabricate a little 'step' above the rear light and mount your jack from there with a gripper on the roof rail to keep it in place. That way, you'd avoid having the extra weight on the door and still have a handy jack access.
Ph
Attached picture of the tool kit contents
I have the Screwdriver, Spanners, Pliers and possibly a Hexagon Key kicking about, PM me if you may need them.
I may have a Jack (Bottle) if you are local to me, they would be heavy ish to post and maybe what you want anyway.
hi gav have MB got complete tool kits in stock ?
the only thing i have is the jack
thanks adrian
Hi Adrian
I will send you a PM later
Darragh, I can always post....
