Strange Gearbox problem...
Hi there,
Been having a problem with my G280 auto whereby when I enter a corner, turn the steering wheel and apply the accelerator the gears do not engage and there is no drive. You can hear the gear box working and trying engage the correct gear, but no drive is supplied to the wheels. It is only when I straighten out the steering wheel and apply the accelerator again does it restore drive to the wheels. Any ideas why this is and how I can fix it? Do I need a gearbox rebuild?
Any help would be appreciated!
GGG
check you auto box fluid levels before you do anything expensive
Or engine mtgs/gbox mtg or kickdown ?
Hi Check the position of the four wheel drive selector lever should all the way back and lying to the left
If the gears work as they should, no delays in shifting or delays or slippages, you are O.K.
First gear usually do not work particularly when not used. There is a cylindrical link on the selector rod which becomes seized or blocked with mud and dirt. This can prevent first gear selection. Other causes, bent selector rod, physical blockage down the selector console.
Thanks, will check but I am sure that it was at a pretty good level and I have spotted no leaks on the floor, etc...
