Rubber side trim
2 replies [Last post]
ajpclements
ajpclements's picture
Does anyone know the part numbers for the rubber side trim/protectors for a SWB 460.
Having got the fixings to reattach them I have realised that some of my strips are not good enough to reattach and I would like to replace them.
Suggestions gratefully received!
Many thanks
Re: Rubber side trim
Here they are from MB, quite pricey but gives you an idea, i have a couple in my garage but they may not be any better as most used ones wont be, all the 460's are 23+ years old, they usually look good until you remove them and the backings have bulged with rust.
These are the SWB versions...
A460 690 08 62 Front Wing (Not Handed) £64.00 each + vat MBUK
A460 690 09 62 Front Door (Not Handed) £44.10 each + vat MB Germany
A460 690 12 62 Rear Wing (Not Handed) £79.00 each + vat MB Germany
A463 690 12 62 Bottom Sill (Not Handed) £94.00 each + vat MB Germany
I think i have one Front Wing and two Front Door ones, where are you in the country, if you are close enough i will dig them out and you can have them if they are better than the ones you have.
The 463's have different type trims for the upper ones.
The LWB 460's are the same for Front Wing and Front Door all others are different obviously!
Hope this helps
ajpclements
Thanks a million!
It is the back ones that I need so will go to MB.
Really appreciate the tip tho
Antony
