LPG - where to put the fuel tank
Hi All
I need advice regarding an LPG conversion for a W463 - g500.
I Have spoken to a number of lpg companies and they all recommend, a lpg tank in the boot, either in the form of cyclinder or on the arches.
However I really dont want the tank to be visible. Therefore Im presuming an LPG tank could fit in the place of the existing fuel tank.
Which begs the question, are there any small fuel tank in the market, that could be squeezed some where under the car?
Or is it just not possible?
Hello Gcouture,
My initial reaction to that, would be in the boot, depending upon the sizes available of the tanks, I am thinking, perhaps two cylindrical tanks, side by side. The tanks would be the width of the floor but no higher than the wheel arch height.
The tanks could be covered by a substantial top sitting on the top of the wheel arch, giving you, your covering and storage space. All you would have lost is a little depth. The idea of small tanks tucked away like the long range tanks fitted on the W460's may not sit well with the LPG fitters, firstly, the connections in between the two tanks could be messy and the more connections you have, increases the risk factor of possible leaks.
My only concern is, accessibility to the battery, which is at the nearside rear wheel arch, some models moved this to under the rear seat.
Rakesh has pretty much described my set up, although I don't have a battery there. Works for me. Not a great deal of room lost.
Hi Gcouture
I bought a small petrol tank intended to sit next to a gas tank under G300 ges some time ago and didnt have the lpg conversion done. It will hold about 25 lts I think but was designed for the g300.I'd be happy to sell the tank but it would be worth checking whether it'll fit a 500. It was supplied by tinley tech in Cambridgeshire.
tiny
Just as a matter of interest, is it really worth installing LPG? I can understand it if you purchase a car with it installed, but to fit it yourself? It would take a long time even at 15mpg to make up the cost involved. Then there are usually problems associated with the running of the engine, and some installers, I say some, butcher the vehicle, which is a shame. Just interested in others thoughts and some real numbers.
Cheers.
LPG conversions are only worth considering if you are likely to do over 10,000 miles in a year, other wise you do not recoup the cost of conversion in the fuel savings you are likely to make.
PM sent
Did you tell him to buy a Diesel Spider?
Agree with rakeesh....but you must have decide to do an LPG conversion prior to buying the 500? So would it have been better to do this before realising running a 500 is mind blowing ! If your car is a longtime purchase then it's worth it......although spider has a mod to his car which is in trials...we've yet to her the results! ....spider? Any results yet ?
Hi Peter and GC,
Agree with you that running the 500 is a little on the expensive side regarding petrol.
When I bought my 500, it was my full intention to gas-convert it as I did this with my Range Rover, Chevy Suburban and Toyota Landcruiser with good results. However, in the long run, certain Gas conversions are not as reliable as manufacturers' fuel systems, especially multi-port injection systems which one would have to fit into a post 1997-built 500. After about 40k, problems start cropping up: mainly injector issues (which are expensive to fix as one has to replace the whole bank to get decent results) and software updates for the fueling. We ran our Suburban with a mult-port system for about 130k miles so certainly got the pay-back.....but it did NOT offroad and I had to replace the injector banks and heaters/evaporatos twice. The Range Rover had a very hard life under my ownership: everyday use as well as a LOT of offroading. It ran with a single-port injection, so might not have been as economical as a more sophisticated multi-point system but was VERY reliable. That car eventually suffered from other issues and I sold it with 165k miles on the clock - LPG system still functioning well. Again on the Landcruiser, a multi-port system was fitted: I didn't have the car long enough for issues to have cropped up and it was only offroaded very lightly. I did have uncertainty over reliability of the system, purely bred from my experience of our yank tank.
My point is, I decided NOT to fit an LPG system to my 500 because it is so reliable and IS offroaded all the time. Why mess with a good thing, even if it is expensive to run...........I have only had to change oil and filters and the car just keeps running faultlessly. Although the car obviously uses a lot of petrol, it has cost me MUCH less in maintenance than the other big-capacity cars that I've owned. Overall, as long as I don't use the 500 for everyday-pop-down-to-the-shops-type runs, running it doesn't cost as much as most people would think (and thankfully I am no longer 16, so insurance isn't stratospheric!). So, Gcouture, think about it before having to chop holes into your car because Gas systems are quite invasive.
Hope this input helps and good luck,
Ph
Ha ha your funny......NOT :)
I'll pitch in on this. I ran a '93 300 GES which had already been converted to LPG when I bought it. It had two tanks under the chassis (40l & 30l).
The exhaust had to be rerouted and there was the additional expense of servicing the LPG components not to mention the extra weight on an already heavy truck.
I would advise you to save the money, the tank can only be filled to about 80% capacity and although it burns cleaner is not as economical as petrol. Just make sure the V8 gets regular oil,fuel and air filter changes.
Here are a few figures to help with any decision on an LPG conversion.
If you take unleaded petrol at an average of 141p litre and LPG at 77p litre and assume an average of 15mpg over 10,000 miles then the fuel costs are:
Unleaded = £4270
LPG = £2350
Difference = £1920
You can obviously scale these figures up or down depending on your mileage.
Based on a fuel cost comparison a petrol G500 would have to average 27mpg to equal the LPG fuel cost.
