LPG Spark Plugs
Does anyone have the number/type for the specific LPG Spark Plug for a 300GE. I'm told there is one but can't find a reference? My only issue with my multi-point conversion is I get through Plugs..it only affects tick over making the engine "hunt".
Paul
I used the Splitfire platinum equivalent of the normal plug for the 300GE, which I got from Demon Tweeks. They did 70K+ miles on LPG with no problem at all, and no wear. Although I took them out for inspection at every service, I can't remember even having to re gap them. There are other types of platinum plugs to choose from now, and I think it's this that gives them their long life. Hope this is of some use.
If the engine hunts on idle, I would suggest having the LPG and, or petrol fuel mixture re-checked.
I can't see why you should get through plugs unless there is something wrong with the distributer cap or rotor arm or leads. It seems a bit odd to me. It might be worth getting replacements from Euro car parts.
Thanks I'll have a look for them.
