injector balancing
Hi, have seen these very basic looking devices for checking injector release pressure and spray pattern. They seem to be an adapted 2 ton bottle jack with a pressure gauge attached above a t section from which a section of injector pipe joins to your bosch injector and a diesel reservoir gravity fed into body of jack.
Has anyone experience of these or had a go at making one as i have only found suppliers in USA to date. Presumably the adjustment shims must be available from bosch to adjust release pop. Will try and include link so you can see what i am talking about. Cheers Richard http://www.mercedessource.com/node/5180
Sorry not good at this will need to copy and paste to browser to have a look.
Hi Richard
open www.hartridge.com on the web also used Hartridge test equipment on E'bay
