How to Mount a pressure gauge pressure turbo?
Thu, 15/08/2013 - 17:27
can you please give me advice how the best way to mount a turbo pressure gauge on a OM603.972 GD350 Turbo?
BR
Antonio
Thu, 15/08/2013 - 18:21
Re: How to Mount a pressure gauge pressure turbo?
Hello Antonio,
Are you asking for a permanent mount on the dash or a diagnostic set up?
Fri, 16/08/2013 - 15:50
#3
Just to quickly check you boost pressure, put a tee piece in any of the small pipes connected to the inlet manifold, connect that up to a gauge, just run the pipe out of the bonnet and in through the window, once you,ve seen what the boost is just take it off.
Gordon
G-Restorations
I was looking for a permanent dash mounted,
I think this is relevant information, I don't understand why MB does not supply it is as standard readings, like temp and oil pressure.
Thanx
Antonio
