g 500 trailer hitch/ tow bar
can anyone recommend a good trailer hitch/ tow bar that can be fitted to my g500 2003 model (LHD)
I've come across this one on ebay which looks ok
http://cgi.ebay.com/ebaymotors/2002-2005-MERCEDES-G500-463-CHASSIS-TRAIL...
My orginal one that came with the car has been removed for the DVLA import test and not replaced so now lost.
If no suggestions i will probably purchase the ebay one.
Andy
Andy, as your G was registered after 1 August 1998 you need a type approved towbar. I really like the versatility of the 2" receiver hitch [used to good effect in US and Australia], but unfortunately I am not aware of any with EU type approval. I have one fitted to my Wrangler JK, but only for my bike carrier and tray carrier.
Search www.ebay.de using "mercedes g anhängerkupplung" and see what you come up with.
I've no expertise here, but see http://www.watling-towbars.co.uk/towbar_fitting_hertfordshire.html and the following:
"Type Approval and European Law 94/20EC
Most passenger cars registered after 1st August 1998 (S registration) must be fitted with a Type Approved towbar. These cars have an “e” mark on the VIN plate together with the maximum car and trailer mass. If the trailer mass is not specified then the car is not permitted to tow a trailer, however it may still be fitted with a support bracket to fit a cycle or motorbike carrier.
European regulations were introduced on 1st August 1998 to harmonise the testing and approval of towbars throughout the EU. The regulations apply to all passenger vehicles registered from 1st August 1998 (S registration) which have to have an "e" mark and its maximum vehicle and trailer masses stamped on a plate. The vehicle manufacturer has to nominate the mounting points for the towbar and the towbar manufacturer has to design to fit to these only. The towbar (not the vehicle or the trailer attached to it) is then tested on a jig, to a formula to ensure it is strong enough to pass the test.
These regulations DO NOT APPLY to the following vehicles:
Commercial Vehicles (ie. pick-ups, chassis cabs, vans etc.), Motorhomes, Special Imports (ie. from Japan or America), Front towbars and other cars that are not “e” marked."
I wouldn't risk invalidating my vehicle insurance, in case of accident, by towing with any bracket not conforming to regulations.
Rick
Have a look behind the middle of the rear bumper. there should be an angled plate-like bracket. the european towbars bolt onto this plate (with four bolts). ph
http://cgi.ebay.co.uk/Mercedes-G-wagon-towbar-/320663786393?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4aa90d1399#ht_500wt_949
Is this what you are looking for ???
Resurrecting an old thread
My 2008 G55 is on its way to the UK. It comes with a tow bar as standard, but it has the "ball" hitch which I want to swap for this
http://www.ebay.co.uk/itm/CURT-Manufacturing-13318-Receiver-Hitch-2-Clas...
reason for it is the need to attach a motorcycle carrier.
I assume the item will fit.
What's the legal implication. A tow bar is a tow bar?
might one of the NATO hitches be a better option, old thread with part numbers here
The regulation is that if fitted in Europe the tow-bar needs to have a manufacturer's name and data plate and carry the CE marking (to be legal and for your insurance to be valid).
The original Oris tow hook is manufactured from solid, forged, steel, which will be stronger than any welded, tubular steel.
There is also a vertical weight limit of 75kg (IIRC) for the rear tow hook, so not sure whether a motorcycle carrier will exceed that, if it is to carry the full weight of the bike?
http://www.ntta.co.uk/law/towbars/type-approval
for your import:
'....private imports from outside the EEC do not need Approved Towbars; however, ....
for your import:
Thanks Arnie.
In other words, the vehicle is imported, so I could swap the tow bar. I read that the max weight for the bike carrier is 135kg?
I really don't want to have to use a trailer
There are motorbike racks that will fit on the standard UK ball type tow bar. The advantage of this type of rack is that you can still use the towball for towing with the rack fitted.
I used to have one like this for my motocross bike. The only difficulty is lifting the bike onto the rack if you are on your own.
http://www.davecooper.co.uk/bike-racks/motorcycle-racks
I use an easylifter motorcycle carrier on my campervan - its a twin wheeler at the back but I also had some air bags fitted that can be inflated to assist the rear springs when the bike is on the carrier. No idea about the legality but it works very well.
I'll have a look at the easy trailer.
my issue is that i have the standard swan neck tow bar (with the ball).
Either I buy the Curt 13318 adapter or one of these
[img]http://www.watling-towbars.co.uk/images/clip_image006.jpg[/img]
The Dave Cooper rack is what I want but it won't fit either of the attachments.
What's the easiest solution (I have no space for a trailer)
for your import:
Thanks Arnie.
Yes, maybe in the UK, but if you intend to venture into Europe you might get stopped
also, 135 kg at 50cm from the mounting point is 675 Nm of twist on the mounting bracket.
for your import:
Thanks Arnie.
Thanks Arnie, I won't be driving the G with the rack in Europe, I am based in the North East, I would be bankrupt before I reach the M25 with fuel bills :)
I have emailed the fabricator of the flange with the spec of the rack I want to use. It's either that or the different attachment (which I've seen used many times in Dubai with people bouncing on the dunes with bikes in the back).
Edited to add, this is my current tow bar.
Your current tow-bar is the standard one for the W463 G-Wagen. As you can see its a forged steel affair, which will be a lot tougher than the proposed square-section tubular steel replacement.
The little aluminium plate affixed to it will have the approvals datra.
If you don't want to keep it, they sell for around £250
thanks Arnie, that was my thinking too. Forged steel vs tubular steel. the fabricator I ordered the flange for said it's been tested with 300kg and passed with flying colours. my bike is 109kg dry - 115 kg wet.
I'll keep the original tow bar.
Update on this in case anyone is interested. I've been using the standard swan neck hitch with bike rack plus a flange to make it square.
Watling towbars guarantee the flange for up to 200kg.
The nose weight for the tow bar is 140kg according to Mercedes.
Towbar plus flange plus bike plus carrier is circa 125kg.
It works well but wobbles due to metal flexing a little over the bar length. This wouldn't happen with a square hitch.
If I don't end up buying a small trailer I'll probably still swap the tow bar as I'm not fond of the movement.
Rick,
i didn't realise that you couldn't use these. This is why it must have been removed for the test.
Are they illegal to use in the uk do you know?
I want to use it with a recovery Dolly.
