fuel pump relay
hi all , does anybody know where on 1993 g300 the fuel pump relay is hiding ? rgds stevo
Should be on the passenger side fuse board.
Drop the cover down to reveal the fuse board, then drop that down and it is on the right hand side rear of the board
I think there is space for 4 large relays but will only be one or two
The FPR is probably part number A002 545 20 05 or A003 545 11 05 if original or A003 545 24 05 if newer.
Should also have 6 zyl on top of it with an RPM number also
Relay should Black be circa 70mmx70mmx25mm ish
Hope that helps...
Other threads on here cover bridging it out to see if its faulty..
The OPR (Overload Protection Relay) and its fuse also have some control over the FPR
This is the Silver relay with the plastic flip top and fuse which usually sits in the same area but on the left of the drop down fuse board and is circa 25mmx25mmx70mm
That is where mine was hiding when it went.
Bonjour
