fuel pump relay
Think my relay has packed up...
Bit of a flutter last night, when reversing into driveway, then would not start today, have a spark, but no fuel out of feeder tube with ignition on.
I am working in Europe, so would need to get replacement by mail order, any ideas? part numbers
THX
To test the pump relay (by elimination) remove the relay from its socket, bridge terminal 7 and 8 (connections 30 and 87) and the fuel pump should work. If so, it is your relay. Do this test quickly to conclude. Also check the fuel pump connections, apply direct supply (for safety, disconnect the connections at the pump), if the pump does not work, then it will be the pump that has packed up.
Please supply Chassis No: and if possible, Engine No: as well for relay part number. Some do have engine number cut offs.
Thank you, Rakesh...it may well be a connection problem, as i replaced relay and pump 2 years ago...
J
