Cabin divider
As part of my refurb/TT project I'd like to completely re-do the cabin area. One idea I have had is to make it a separate compartment. I know MB did a metal an mesh bolt on kit, but I was thinking of something more solid. Does anyone know if MB make such a thing, or would I, as I suspect, be better drawing it up and getting it fabricated locally?
All ideas very gratefully recieved.
Thanks.
Ian
PS Work should be starting very soon. Pics to follow.
I can only come up with a few part numbers on EPC for a solid metal divider / bulkhead and none of them are available from MB anymore.
Radio Cabin Bulkheads...
A460 710 03 01
A460 710 04 01
A460 710 06 01
A460 710 00 36
A484 710 00 01
A484 710 05 01
So not much use really....
Never seen anything in Fibre Glass or such like
All others are just wire mesh dividers
hi there.
frome what i understood you wish to divide the driver area from the rear bench seat where the passengers sit and not the boot area....
if so, i have a military style mesh devider i picked up a few months ago... its ultra rare ! i have it for my cabriO g but i am in two minds as to whether or not i want to fit it...
rgds hus
I have not contributed because I have nothing to add. I am aware there are one or two pick up versions about, but I have not researched these as yet. If streatched, all I can contribute is, to use the rear end as parts to build your partition.
The rear outter quarters will have to be formed in and the middle, can be the tailgate, welded in between the quarter panels. Retaining the rear window glass. Obviously, the crudness will be needed to be refined. The advantage here is, these panels are already part of the vehicle and can be put to use.
If you want some EPC pics of what is listed just PM me your email address
ford transit connect van lwb has a 2 piece bulkhead cab divider with a section for a window through already formed into it ,i have such a van and take the top piece out when i carry friends in the back on long journeys i am sure it could be altered to fit in to a g as it is similar dimensions ie. a lot of the work is done for you and it should be available new or second hand failrly cheaply, do not make it totally air tight or the heater will not work very well ie. it will not ventilate the cab space .
please look on gumtree advert ref. 109468009 that is what you want £40.
hi ian . pm me your email and i will forward you the pics of the mesh divider i have off a swiss army G.
rgds hus
BUMP
Huh....smiley's not working.
