617 injection pump locking tool
I am still trying to get the engine back into the 460 and now have a new problem, a significent oil lelak has developed from around the injection pump to block 'o' ring. The job looks quite strightforward but while I had the injection pump off I thought I would check the static timing of the pump is correct and so need a locking pin. Does anyone know of a good source or has anyone made one?
I thought there ma be an exisitng thread for this but cannot find anything.
James
Hi James
I have a copy of the OM616/OM617 Workshop Manual
I have been right through it twice and there is no special tool listed for locking the pump
It does not show either an MB supplied tool or a local supplied or make it yourself option
In fact i cant find a listing for the operation itself?
The manuals are quite comprehensive and even give drawings and dimensions of any tools you need to make yourself
Perhaps a more hands on member like Axel or FCP or Fixwin might answer you question
Hi James
They never fitted the OM617 into the W124 series of cars?
The OM616/ OM617 went in the W123 or earlier
The W124 had the OM601/OM602/OM603 series of engines
Short answer would be that you do not...would guess you can get it to TDC and then mark pump position on block and then gears as it comes out.. suspect there will be marks on the gear if you took the vacum pump off to look at the other end. Actual timing is then by spill method i.e. slowly turn engine over and see then it creates a drip from a U tube on injector 1...guess there are marks on flywheel for that timing point. Old School.. not done it but know of it.. someone who has will be along shortly!
Yep, the manual says most of that ;)
PM me your email
Hi All
this inline pump can be installed 180 degrees out causing possible damage to the internals when trying to adjust .....
Hi Gav
Thanks for the response, let me clear this up. I use the MB W124 Haynes Manual as the source of info for the 617 engine and this clearly shows the use of a screw in tool to lock the injection pump for static timing. I don't know if this is the same as for the G-Wagen. If not, what do the pages in your workshop manual say? Unfortunately I don't have a copy of that.
James
