463 Wheels on 460
I've been thinking about replacing the 15" CW/ Bobbet rims and 33" BFG MTs I have for a while as they quite are noisy on road (although good if you are off.
Yesterday I bought the set of 16s Ashtroths that Howard had for sale which I plan to fit a set of BFG 275/85" ATs to.
I know that they will need a set of spacers for a standard axel 460 - does anyone have any reccomendations for spacer width ? (I know that 25mm is the minimum).
I'm also after at least one more rim as a spare (actually I need 3 by next year, but for now just one would do) - visual condition not too important as I'll get them all re-finished in black anyway.
I got a set of spacers last year from these chaps in Germany .......nicely engineered and fitted fine...60mm per axle.
http://www.ebay.co.uk/itm/Spurverbreiterung-4x-60mm-Mercedes-G-Modell-46...
Steve
Thats 60 mm per AXLE ...not 60mm per wheel ....the spacers are only 30mm each
Steve
I assume the new wheels are the normal ET63 back spacing and are seven and a half inches wide. Normally a 30mm spacer would give enough clearance of the steering arm but with the wider 285 section tyres I think you would need to fit the wheel and tyre with a mocked up 30mm spacer on the front then turn it to full lock and see if the tyre wall is clear of obstruction.
just as a matter of intrest , are there any other wheels that fit the G , like landrover et all. as they may be a bit more avalable and well just cheaper. i really ment this as a new post, i will repost , sorry
you can fit landrover wheels with adapters these are around the £200 mark they also act as spacers and will put an additional strain on the wheel bearings
http://www.rakeway.co.uk/page34.html
Good timing...I've been looking at the current model w463 wheels and thinking about getting the look on my w460. I see that they use 18 or 20" inch wheels fitted with 265/60 or 275/50 tyres on the 20". I understand that any wheels I found would have to have the correct offset and pcd for mounting and would use spacers or not. Would anyone know what 'normal' mercedes car wheels fit in these sizes? I saw these 18" ones on Ebay 270834097381but the guys says they dont fit G's. he has a list of tons of Merc cars that they do fit as standard so i guess they may fit with spacers.2nd question is what is the tallest section(HEIGHT) receommend for the 265 wide tyre? 70,75 80 perhaps? i'd like to fit a big wheel and tyre but with a balnce for handling and being able to get in without a step. Also to reduce cruising rpm's.
The G Wagon has an unusual PCD of 5/130 so wheels from Mercedes range of saloon cars will not fit that bolt pattern.
There are a few other vehicles with a 5/130bolt pattern, Porsche Cayenne, VW Touraeg, VW LT Van, Mercedes Sprinter Van. However you need to check the center hole is the correct 84.1mm size.
You can buy adapters with a different PCD that fit onto the hubs which will allow you a bigger choice of wheels.
Ok . Is a Vito van a Sprinter van and would the wheel fit straight on?
no, its not and they won't swap
Adding an adapter has the same effect as using a spacer and needs to be taken into account, plus using spacers and adapters will imply the use of non- standard wheels. I.E neither tested nor recommended by the manufacturer.
The above website provides useful information on the different wheel options
Thanks for the link. The only ones missing are the current 18 and 20" G wheel options but this is great.
The query was about fitting wheels from other manufacturers, that don't actually fit G-wagens and therefore need adapters. My point was that not only do these play an adapter role but also act as spacers too. I don't have a problem with spacers as such provided you have long enough bolts but adapters are bolted onto existing bolts and this is an entirely different strain and not designed for...but if you are happy with that, good luck
Thanks Steve - 60mm per axel seems a lot, but I don't really have a feel for how much offset the Ashtroths will need with a set of 285/75s will need in order to remain within the line of the arches I have (which are ORC suplied so perhaps I should ask them!)
