463 Rear Mudflaps
One of my rear mudflaps (originals) has broken off and looks like the other one wont last much longer .....
Would like to replace them but not sure whether to go for MB originals (I assume they're available - cost?) or can anyone recommend an aftermarket alternative? Not sure about GWOA ones as I personally don't like the red 'G' logo!
Thanks.
Have some of these floating around the offcie I am working in. Come in Blue, White or Yellow (as pictured). £10 per pair.
Hi Huw,
I am not sure about the fittings, you may have to drop a note to Gav.Helme on that one, though I will check with David when I see him, and (no promises here) will see if I can dig up and photo the white ones.
The do look similar but more shiney than the orginal MB ones, not sure if anyone has had them in the past, so will open this up to any members who have had them beforehand to comment
TTFN
Joe
Straight swap over, they are fairly strong made of thick rubber ... Mine coming out of my car and replace by original one .
Hi Huw,
I am selling on the 500 very soon, It is getting serviced just now , and want it as original as possible.
The gwoa mud flat a bit too something and like the original better ... took long time to get good second hand one set !!! Only just manage without having to pay an arm and leg .. You can have them once removed if you want.
No problems at all, That is if I got them back yet !!! Car is at Gibsons Autos just now ...
Hi Huw
Attached picture, part numbers and prices for the factory fit Rear Mud Flaps for your G
Gav, Any differences between 460 and 463 ?? Link above show 460??
Hi Huw / Fred
I have used the chassis number for Huw's G500 463 to work out the numbers
Yes most of it is the same as 460's although there are different versions for individual models.
There are 2/3 types of flaps and various bracket and stay combinations, however most of the Wagons run these type listed
Fred the ones for your G500 463 are identical and your Blue 230 460e flap are the same but the brackets slightly different
? 500... you getting another one or saying good bye to V8's?
Hi Spider - thanks for that - the white ones may well suit - the others are a bit garish for my taste!
Are they fairly robust like the MB originals and do they come with necessary fittings as the old fittings are somewhat corroded?
Huw
