Wooden trim
On my 463 SWB 300G there is a small piece of wooden trim on the passenger door which effectively hides the screw that hold the grab handle onto the door. The trim in fixed to a short piece of plastic with two round plugs that slot into two round holes in the door. Unfortunately these two plastic plugs have become broken.
Does anyone know if it's possible to get hold of the short plastic piece complete with plastic plugs so that I can once again fix the wood trim to the door (rather than using some double sided gaffer tape which is what I'm doing at the moment?
If it is possible does anyone know the part number?
It was only ever available complete with wood trim, at a very expensive price.
It's most probably NLA now.
Use double sided 3M adhesive foam tape to re-attach directly, without the plastic pins.
Can I have your vin and I'll have a look
Gordon
The plastic backing to the wood trim was never available on its own.
I know because I had to buy the whole thing some years ago (around £100).
Yes, the part-number is for the complete piece.
The plastic becomes brittle and the pins will eventually snap on removal, even if you take great care. It's not the best design, but I note that the long wood strip on the dash has metal pins, which are more robust.
If you re-attach with the double-sided foam tape, make sure it does not foul the pin-holes in the door part, as it will then only contact and stick to the small area of the pin-hole borders, which are slightly raised, and fall off when you are not looking.
The Hook & Loop may be a better option.
Do you mean the short curved piece in front of handle about 4 inches long
Mine too left the plugs in the door card and the pins
I carefully drilled pockets in mine and set some aluminium dowels in epoxy resin
Its been fine since and bugger me i had to remove it to fit a new lock set but it was ok
Dont drill clean through wood if you slip![]()
G
Thanks Gordon.
WDB46322727078892
