Windscreen going milkey in the bottom corners.
The corners of my windscreen are gong milky dose that mean the seal around it going??
Isn't that a sign of delamination....? Not sure.
Yes delaminating at the edges.. the screen is made up of glass outer and inner.. with a plastic sheet in the middle. If moisture creeps up from the outside it causes the plastic to go cloudy.
Not the end of the world....new screen is only about £100 .....
SK
Silly question, however have you tried using some windex to clean the corners? I know sometimes road film can build up in the extreme corners over time, and can be missed in the cleaning process. I do this from time to time and it removes the porblem. If its not that, then it could be the lamination of the windscreen.
Tinted A460 671 05 10 £113 + VAT
Clear A460 671 02 10 £83.50 + VAT
Sounds like simple de lamination to me...
I did not know that. Thank you..
