Window switch
Fri, 19/10/2018 - 22:41
Hi all
My passenger front window has stopped working, I have changed out the switch to no avail, just wondered if it may be the window control unit, can anyone tell me the location of the control unit on a 1999 G500?
Thanks in advance Freddie
Tue, 23/10/2018 - 13:38
Re: Window switch
are you able to swap the switch to the drivers side to check that its at fault or not
Tue, 23/10/2018 - 19:54
#2
Re: Window switch
Can't you hear the Motor working or clicking?
Wed, 24/10/2018 - 17:40
#5
Re: Window switch
Suggests the switch is working, so therefore most likely the motor
I’ve already swapped out the switch with the same result
