wheel wobble
Fri, 28/10/2016 - 18:46
I have ex German army 250G ,have very bad wheel vibration/wobble at roughly between 80/100kms speed,have had all 4 wheels( military) balanced,still have problems.can anyone help/ suggest?
Fri, 28/10/2016 - 19:03
Re: wheel wobble
Your steering damper needs replacing
Sat, 29/10/2016 - 09:02
#2
Re: wheel wobble
If you strongly feel the wobble transmit to your steering wheel then at the speeds you have indicated; as Gordon has mentioned it is your steering wheel damper that needs replacement.
There are two types available, a standard and a heavy duty one. My suggestion is to go for the Heavy duty one. It is twice the price or so but lasts longer.
Sat, 29/10/2016 - 18:35
#3
Re: wheel wobble
The description you give is classic steering damper failure, aren't there some cheaper options using LR Disco steering dampers than standard fitment items?? Easy to swap them over for a DIY mechanic too
