Wanted to buy: G500 ABS computer
Hi all, I am looking for a G500 ABS computer, if anyone has one available please email me at kiato4@yahoo.com. Part # is 025 545 37 32 (Bosch part # 0 265 108 046). Thanks.
It is very unlikely you will find one second hand. You may have beteer luck in having your current one repaired.
I had a nice warm pudding for lunch to-day so my mind is as thick as the pudding; I don't quite follow.
Don't you have an ECU at all and if you do, yours is one for a G320? I do not see why you need a G500 ECU for your ABS?
Are the rear ABS sensors the same for G320 and G500? If not just change the sensor to G320 if fittings allow.
If you have changed the rear axle off a G500, then what of the front axle, is that a G320's? If the axle ratios differ from front and rear the vehicle will have problems in driving and stability not to mention excessive forces on transfer box. Something in it will blow out.
More input please.
If you got the rear axle from a 99 G500, can you not get the abs from the same vehicle?
But if you still have the G320 axle on the front, how will either abs ecu work correctly?
Thought you would have had enough of ECU's this week Roly :(
Theres an earlier part number that is maybe the one actually on the ECU's you will find second hand....
A020 545 47 32 (Bosch 0 265 108 032?) it is replaced by the A025 545 37 32 (Bosch 0 265 108 046) you mention....
Fitment... A020 545 47 32 and A025 545 37 32
463 series...
G300TD OM606
G320 M112
G500 M113
G55AMG M113
Fitment... A025 545 37 32 only
461 series...
290GDT OM602
Hope that helps
Did you remove any sensors at all? I suspect this is your problem. Had exactly same symptons on mine all due to one rear sensor not fitting flush enough and the remains of an O ring in the aperture.
Have you found one yet?
How big and fat is the carrot at the end of the stick if I can find one for you?
I know, I have been having quite bad luck searching.
I actually do not have a current one, I replaced my 1995 G320 rear axle with one from a 1999 G500 and I need the G500 computer to make my ABS work right with the new disk brakes.
