W463- 1993 300gd Anyone had an issue where the indicator light on dash stays on?
Mon, 18/09/2017 - 18:28
W463- 1993 300gd Anyone had an issue where the indicator light on dash stays on.
Mine is doing this, just wondering if anyone else's truck has had the same issue before I go looking.
Thank's.
Mon, 18/09/2017 - 23:17
Re: W463- 1993 300gd Anyone had an issue where the indicator ...
Indicator light for what ?
If you are referring to the actual turn indicators, then you may have a faulty indicator relay module.
Tue, 19/09/2017 - 09:52
#3
Your turn-signal relay module is probably stuck or burnt -out. You will find it in the drop-down panel above the front passenger footwell. Open the flap for the fuse board (two twist-lock fasteners), then undo the two Philips screws - one in each corner and the panel will fold down.
