W461 Clock advice
My first post in this forum. I have a blank area in the instrument binicle that I would like to fill with a clock (time piece)
The wagon is a W461 from 1990
Are clocks available from later seies that would fit the "hole"... The vehicle has a 24v system and negative earth but I can wire it onto one of the 12v battery terminals with an inline fuse.
My alternative would be to buy a cheap stick on minature quartz clock but it would look lost ....
Any, and all, advice would be most appreciated
That is usually the place for the rev counter, but optional
I think it is the same diameter as the clock which usually sits in the lower centre console to the left side next to the headlamp switch
I have some used 12v clocks for sale
PM me if interested
I think I would opt for a RevCounter as standard. The console clock is indeed the same diameter though and would be the easier connection. Clock makes sense if the centre console one is missing
edit: btw - I like the shading on the speedometer indicating the 'sweet spot' from 50-60. And that is km/hr !!
The "sweet spot" showed you the recommended speed in town, standard feature at the time.
