W460 headlamp surrounds
Hi All,
I'm looking for some new/good second hand headlamp surrounds? mine are very crusty and barely hanging on. Any suggestions?
Hagar
Message for you on your email and PM
There are now plastic ones available from MB that replace the rubber ones.
If it is the rubber ones you are after, then furnish me your full chassis number. My will enquiry for this will be Austria.
| £ 28.00 | A 461 880 01 40: | COVERING (VERKLEIDUNG) (kg): 0.39; plastic headlight surround Left |
| £ 28.00 | A 461 880 02 40: |
COVERING (VERKLEIDUNG) (kg): 0.39; plastic headlight surround Right |
Prices from 10 years ago
The 460 ones are rubber bonded to a steel backing plate which corrodes until the rubber falls off. Better/more robust but prone to weathering to a velvet matt.
The 461 plastics ones are lighter by a 1kg each! They have a pimpled texture. I had to close up the wing hanging hooks a little to get them to be level with the wing top and use a washer in with the securing screws. Easy to paint after you have sanded them down but no doubt will break before the rubber ones.
Thanks everyone, I have some of the W461's on order from MB, £28 each +VAT so pretty cheap!
Hagar
