W460 Engine & Gearbox Issues
9 replies [Last post]
twiggster73
twiggster73's picture
I have a 1985 LWB G Wagon 2.8 Auto and I have been having problems with the engine & gearbox:
Engine - Low in power and mis firing - I have changed all spark plugs/leads and injectors but still mis-firing. I believe that the petrol pump may be starving the engine of fuel as it is whining quiet loudly when the engine has been running for a while. I think some rust has come away from the fuel tank and is blocking it?
There was also a lot of blue then grey smoke when the engine was warm, I suspect that the head gasket may be the fault?
Gearbox - Even though it has been looked at by a mechanic the gearbox is still slipping between gears and will not go into 4th gear at all?
If anyone can give me any advice or hints I'd appreciate this. Such as what other makes of Mercedes parts can I put into my G? People say a lot of parts are the same as the Sprinter and the E Class?
Thanks again
Re: W460 Engine & Gearbox Issues
Please see comments, below:
twiggster73 wrote:
Blue smoke is a sign of burning engine oil. Grey smoke, if it does not smell sweet/acrid, is probably dirty injectors or lack of fuel. I would;
1.) Check the compression on all cylinders and carry-out a leak-down test. If this passes, then your blue-smoke is probably valve-stem seals that need replacing.
​2.) Change your fuel filter and run some injector cleaner through the system, like BG44K. If you have a rusty or leaky tank, start by addressing that first. The fuel delivery pressure from the pump should be around 3 bar.
​if sweet/acrid grey/white smoke, it may be due to coolant leaking so check cylinder-head gasket and for any oily signs in the coolant or even low coolant level.
​Also, make sure you have a clean air filter an no vacuum leaks after the throttle, which brings us to the gearbox...
Check you have the correct level of fluid (Dexron-II type) in the gearbox. This should be checked with the dipstick at the rear of the engine and with the engine running in P or N. It's surprising that many check the level with engine off, resulting in a low fluid level. It may be good to change the gearbox fluid and pan filter and gasket, whilst at it.
​Then, check that all vacuum lines are intact, without leaks or broken connectors, and that the throttle linkages are good without play. If they have never been changed, then this is the time. The gearbox determines its shifts from throttle position as relayed by the throttle linkages and cables and also by the manifold vacuum.
If you still have issues after this, then it may be time for an overhaul, eevn though this is a very robust and usually trouble-free gearbox.
​Note that the gearbox is designed to start in 2nd gear so you should only notice two up-shifts: one into 3rd and another in to 4th. 1st gear is selected by placing the lever all the way down to '1' or 'B'
in your case, the W123 from the 1970's as far as the gearbox and engine. You should be able to find a haynes manual or equivalent. Brakes and some other parts like door handles are from the Mercedes vans of the 1970/80's
Thanks again
also, read this:
http://www.peachparts.com/shopforum/tech-help/9214-misfire-idle-clogged-plugs-w123-m110.html
These engines also have a rather primitive cold-start enrichment device, which can wear and go wrong.
twiggster73
Thanks thats great I'll get some petrol sealant (Por kit) and see if that sorts the pump out.  Cheers
If your fuel tank is rusted through, POR paint will only be a temporary fix.
panzer
panzer's picture
POR15 is amazing stuff. A friend used it as temporary fix on a diesel fuel tank 5 years ago and it is still leak free now.
twiggster73
THANKS  I'm attempting it this weekend I'll try and update later
twiggster73
HI still getting around to doing the fuel tank
Its going into the garage to check the oil and vacuum pipes etc.
I have included some pictures and it seems that I have a couple of pipes that seem not to be connected to anything. I'm not sure if you can identify them at all? One is a rigid pipe and the other a flexi pipe.
Picture 1 is pointing to the gear selector? which seems very loose and I think something should also be in this gap?
Also there is a shelf next to the battery which looks like a smaller battery place?
Any help is greatly appreciated
Use this website to find the parts diagrams you require:
https://partsouq.com/en/catalog/genuine/locate?c=Mercedes-Benz
  • Scroll down to 280GE
  • ​Select one of the models (doesn't matter which, really, for engine parts)
  • Select Engine > Engine Air Supply > Accelerator Cable / Linkage
You'll then get a detailed parts diagram to enable you to see what should be there on your engine and what's missing.
https://partsouq.com/en/catalog/genuine/parts?c=Mercedes-Benz&ssd=%24HQARW1BYUHJIFkACC1sIXUFZXh8WWwIBWwgAAAMGTkppKxINVQN2QkNcTngiRA%24&vid=3464&gid=10485&q=
Then, do similarly to search for the vacuum lines and any other part you may require.
You can also try an Image search on Google for " M110 280E throttle linkage " and this will give you some pictures for a better idea of what should be there (All 280Es are similar).
https://www.google.co.uk/search?biw=1707&bih=843&tbm=isch&sa=1&ei=AdoOWu2oFYvPgAayrY-ICw&q=M110+280E+throttle+linkage&oq=M110+280E+throttle+linkage&gs_l=psy-ab.3...13451.14439.0.15146.5.5.0.0.0.0.59.268.5.5.0....0...1.1.64.psy-ab..0.0.0....0.YIZ2dfp5Jyw
You are probably missing a spring tensioner in the hole you point to in the linkage.
The ''Shelf' you mention (very bad pic!) is probably the storage support for the bottle jack.
The U shaped pipe looks like the breather for the gearbox. It might normally have a small rubber hose with a filter unit on the end.
The clear (yellowed) plastic pipe (if that is what the picture intended to show) is what is normally used for the vacuum system for the brake-servo and other systems that use vacuum.
Looks like your or your mechanic could use a copy of the MB Workshop Instruction System (WIS) and the Electronic Parts Catalogue (EPC). Look them up on eBay, if you have a spare fiver. The proper EPC is similar but a little better that the website listed here.
twiggster73
Thanks for the help I'll keep you posted
