W460 5 speed manual gearbox rebuild, or replace…
Fri, 04/11/2022 - 09:46
Hi all, so unsure exact issue but 2/3rd gears not selecting, can anyone recommend a decent specialist or as far as gearboxes go could any gearbox company tackle a rebuild?
A few companies have mentioned parts will be hard to get hold off, any recommendations on where to source parts for the rebuild? Thanks in advance
Sat, 05/11/2022 - 00:26
Re: W460 5 speed manual gearbox rebuild, or replace…
Are you sure it isnt the common issue of the selector rod bushes being worn and the rods binding?
Thu, 10/11/2022 - 16:51
#2
I agree.
Sounds like a fairly common selector rod problem.
If the gearbox is actually damaged internally, then replacing it might be simpler than a rebuild and getting a replacement shouldn't be too hard. Probably, like engines, the same gearbox can be found in other MB. But others would know more about that.
