Various bits- blower, wiper spindle, fuel guage tinkering advice...
28 replies [Last post]
tomcutting
tomcutting's picture
so after doing 250 miles on my 1987 w460 I'm starting to understand it better and had lots of fun but have identified 3 issues that need addressing-
Fan blower doesn't get hot so the Windows steam up a lot, I've read something about the seals bonding over time and this is a common problem, also that it's behind the glovebox but no further info - can someone point me in the right direction to further info?
Passenger side wiper blade was making a noise and on investigation the spindle has play and rust and could do with replacing (also letting in water which I also understand is usual)
Can I tackle both jobs at once?
Last one is fuel guage isn't working, the dial moves when ignition goes on but just a few centimetres, apparently it's under the carpet in the boot but before I unscrew the door plate and pull it all up what do I do when I'm down there!
I've checked the manuals but these areas don't seem to be covered
Re: Various bits- blower, wiper spindle, fuel guage ...
Is heater putting out hot water, is it plumbed in? Heater will never be like a new car but should clear windscreen ok, possibly is leaking through worn wiper spindle, enough has been written here on that job, I think 460 spindles available individually? Fuel tank, get access to flap, lift up carpet etc. Find fuel sender wire and ground it out ( earth it temporarly) fuel should read full when you do that, indicating sender faulty, if it doesn't possibly gauge on dash playing up or wiring issue. Is it a plastic fuel tank? Possibility sender can be repaired but it's tricky!
Who installed your engine, other than the above problems is it going ok?
cox.adrian
cox.adrian's picture
   follow jason  advice re fuel sender / heater
    the wiper spindles
    a bit of a PITA job
    0008204246
    0008204346
         are 90 euro incl tax & bank
           let me know if you want a set
               adrian
tomcutting
have overridden the feed for heater so now it's locked to toasty warm and no frosty Windows, looks fairly simple to replace in the future too, think I'm going to leave the spindle job for the garage and the fuel guage I'm going to investigate on Friday when I'm doing a clean and rustproof session
as for general thoughts I love it! the engines got so much power it's crazy, I feel like I can go anywhere. I've had a fairly heavy right foot so not getting the best fuel economy but I can absolutely believe with the right kind of driving this do up to 30mpg, I do need to get used to the gear change from 2nd to 3rd at it is a bit of a clunk but I don't expect much from an old fashioned autobox
tomcutting
some pics...
Looks very nice, when you get a minute, please post some pics of the under bonnet? Not very often G owners say so much power!
tomcutting
No problem, will do tomorrow
Just to cover the very basics regarding low temperatures from your blower.
Firstly, make sure the engine is operating within the normal operating temperature. Thermostats failing are fairly common whereby they could have failed in an open position hence the engine temperature reads low and heater blower does not blow heat. The needle for the engine temperature gauge should sit at the upper part of the digit 8 of 80 degrees. The needle sitting as described actually reads some 90 to 95 degrees temperature. If a lower reading is achieved; replace the thermostat.
Secondly, there is a heater control valve by the off side heater matrix. This can get stuck internally in an open or shut position depending on how the valve has been set throughout the summer or winter. The rubber seal inside bonds with the internal sealing face over time. No matter which position the valve is set, open or closed, when ever the valve sits on its sealing face or bottoms out, bring the valve off the seat a little so it does not bond on. Otherwise put into practice some things that should be regularly worked on a G-Wagen to prevent them from become problematic. Work the valve On and Off several times a month and don't let it sit in one position all season long.
Once the valve is worked free or replaced good heat should start flowing.
Wiper spindle; depending upon the chassis cut off you may get individual spindle for replacement or it will be a case of the whole wiper link. The link and spindles are handed for a Left Hand or Right Hand drive vehicles.
The fuel gauge could be a earthing issue where to sort that out you need to get to the cover plate under the carpeting in the rear luggage area. Difficulty could be removal of seized and round screws holding the kick plate across the width of the rear door. More so the fuel sender unit may need careful disassembly to internally clean and flush out the collected and trapped dirt and bacterial material out. BE very careful working here the fuel float is guided by a very thin length of wire easily broken and no ordinary channel for repair. Although it is repairable and the wire is actually is detonating wire. Put it another way, a person of my ethnicity would not want to be caught sourcing for detonating wire in todays' political clime.  blush
tomcutting
thanks for that, I'm going to try and get access on Friday morning, in the meantime I took a snap of the engine too : turbo intercooled om606 with a dieselmaken manual fuel pump (6mm element) giving it more grunt
tiny
tiny's picture
hi
is that a nifty little air filter you have there ?
I have the same set up ie 606 with modified 603 pump 6mm elements but with a larger KnN filter
the 606 makes these trucks a joy to drive in modern traffic
cheers
tomcutting
yeah, apparently this air filter makes the engine a bit quieter than the k&n but I'd like to hear the difference! was yours done by dieselpumpuk?
tiny
tiny's picture
No done before I bought the truck by dieselmeken AB in Sweden the fuel gallery on mine is now said to be 90 cc but I don't have paperwork to this effect.
Truck goes/pulls very well ( I have the 6 speed manual g'box ) so I tend to short shift it up through the box as power band fairly brief. I've thought about having diff ratios changed but have decided better for towing with the standard diffs.
cox.adrian
   the cut off for separate wiper spindles
   WIPER SPINDLES SINGLE up to VIN number ENDING ( 066443. )
tomcutting
So got under the carpet and the earth test works, the gauge and the low fuel light switched on when earthed- what next? Shall I disassemble and clean or just order a new unit? Anyone have idea on the part number and price? Also found the spare tyre is only held on with one bolt, dodgy? Should be three right? Part number/thread for these too? Thanks! Tom
panzer
panzer's picture
Yes three nuts and a padlock is not a bad idea!
cox.adrian
wiper spindles on stock sensor 0095420717 (would need your VIN) seal ring 0009975149 (would need your VIN) spare nut 4609905050 on stock GRAZ closed till 11th jan
tomcutting
so rather than buying two Mercedes nuts and a padlock for the same money I can get 5 locking nuts and secure the whole car... http://www.europerformance.co.uk/pages/products/product_info.mhtml?produ... any thoughts on these one? worth it? looks like a good idea to me but I might be missing something...
OEM alloy wheels require radius-seat bolts, 45mm long, The ones you have shown appear to be connical. I found these lock-bolts to be very good, and which are used by Mercedes and others. eBay item 231137873011 Then TUV approved bolts, eBay item 230860150578 And caps for Audi, which fit well and have slim removal clips that fit in the wheel holes. The set also includes one cap for the wheel lock-bolts above. eBay items 252235116888 (enter eBay item number into the eBay search bar)
tomcutting
thanks arnie, shame I can't get 5 so all the wheels are secure- have emailed them to see anyway
The spare wheel is usually secured by a padlock with a long shackle that goes through the support tube of the wheel carrier. It's pre-drilled for this. You can get these for little more than a fiver from B&Q etc. In any case, you need bolts for the 4 wheels and nuts for the spare wheel.
cox.adrian
the wheels are bolts the spare is nutts
tomcutting
ah, when I took the cover off I took a pic and it looks like a bolt , in the two empty holes there are threads too, so what do I need to do you think?
tomcutting
that's a it low res to see so have zoomed in
I see what you mean. Maybe you have a modified or non-standard wheel carrier. The wheel normally fits with its outer face facing the rear door, such that the tube protracted through further on the inside of the wheel where a pad-lock can secure it. The wheel carrier should have three studs to affix the wheel with three nuts. I'll try to find a picture.
tomcutting
guess that's positive, makes it look smarter when not using a wheel cover had a fun drive today in the vale of York, still a lot of water everywhere though
G-Restorations
G-Restorations's picture
Do the diffs, the difference is amazing, I have OM606 80cc pump , six speed box and 4.1 diffs. I can cruise at 85-90mph all day and I've seen 113MPH, 90 MPH is at 3200 RPM towing isn't affected Gordon
cox.adrian
you have a reverse wheel holder good side out this is after market STD is good side in against the door this is OK but will put extra weight on you hinges do not drive with you door open or not closed correctly adrian
tomcutting
definitely like to chat about this for the future, done 250 motorway miles this weekend and cruising at 80 rather than 65 sounds nice
tomcutting
oh and fuel gauge now works, luke stripped it down and the refitted with no issues!
