synchro rings?
5 replies [Last post]
Maxwell Smart
Maxwell Smart's picture
My car has been popping out of third gear quite frequently lately. This started happening after the garage accidentally put the gear lever on backwards. They have since rectified this but it is still popping out of third gear.
They said they believe it is the synchro rings which need replacing and that the cost do so is £1100+vat.
What do you think?
MRKBENZ
MRKBENZ's picture
synchro rings?
Hi Maxwell
This could be the case but in my experience it is usually the torque setting of the selector rod, the bolt that holds the selector link to the selector fork needs to be torque set this can be done with the g/box in situ you will need to check the torque setting's from the technical data i cant remember them of hand but if you cant get them mail me and i will get them for you. If this does not resolve the problem then it prob is the synchros but it is worth trying first
regads Terry
Maxwell Smart
synchro rings?
Thanks MRKBENZ, I'll take a look at that. It certainly sounds a lot cheaper...
I need to point out that the whole reason the gear lever was turned around is I wanted to change the boot but the gear knob was frozen onto the stick. Do you think that the torque setting could of been knocked out by the garage trying to either unscrew the knob or in the end removing it?
MRKBENZ
MRKBENZ's picture
synchro rings?
cant be sure of that they somtimes need reseting just because they have worked loose
regards terrry
Greeney
Greeney's picture
synchro rings?
On a lighter note did you get a nice gear lever knob? If so where from?
Maxwell Smart
synchro rings?
Nah I think the knob was seized to the lever, thats why I finally gave up and I believe the garage gave up too and resorted to removing the whole lever - hence it being backwards.
Thanks MRKBENZ will try and sort it out.
