Spare parts 463 1991
Does anyone know anyone breaking a 463 we have a small list below of bits we need?
Hamish
I am looking for the following? G wagen List 1. Window switches electric x 2 2. Brake fluide tank cap 3. Front bumper end caps 4. Number plate holder front 5. Clutch fluid cap 6. The pipe from the brake servo to the abs clear pipe at back of engine bay. 7. Drivers door card and passenger door card 8. Front uv joint both sides 9. Engine thremo gauge 10. Electric Arial |
window switches are same as w124, brake and clutch caps go to mb there quite cheap, servo pipe can be bought by the meter,check rest out with mb or ebay.de
Hamish
I am looking for the following? G wagen List 1. Window switches electric x 2 try ebay for W124 switches: http://www.ebay.co.uk/sch/w124+window+switch.TRS0&_nkw=w124+window+switch&_sacat=0 2. Brake fluide tank cap
Try loacl MB dealer or ebay 3. Front bumper end caps
Dealer, very expensive or try ebay.: http://www.ebay.co.uk/sch/i.html?_Xw463+bumper+cap.TRS0&_nkw=w463+bumper+cap&_sacat=0 4. Number plate holder front
If you have a standard bumper there is no number-ptae holder. if, on the other hand, you have the version with th e front tow hitch, you might try to look on German ebay or your local dealer.
5. Clutch fluid cap 6. The pipe from the brake servo to the abs clear pipe at back of engine bay. As mentioned above, your MB dealer, by the metre.
7. Drivers door card and passenger door card try ebay. Three are a few on there: http://www.ebay.co.uk/sch/i.html?_from=R40&_sacat=0&_nkw=w463+door+card&_sop=12
8. Front uv joint both sides 9. Engine thremo gauge The sender can be found at euro car parts ofr similar. the actual gauge, you may need to find a W124 instrument cluster and remove it from that.
10. Electric Arial any local I C E dealer or ebay.
Yes, I don't know what happened to the formatting.. I've now lost the links, but if you search on ebay for;
W124 window switch
W463 bumper caps
W463 door cards
...you will find what you are looking for
For the number-plate holder, I guess you have the bumper with the front tow hitch, as the standard bumper has the number plate affixed directly to it.
For the brake-fluid and clutch fluid reservoirs, you can find the caps on ebay, but probably cheaper from your local MB dealer.
An electric aerial can be found from any local ICE dealer or ebay.
In case it's of any help, the part number for the brake fluid reservoir cap is MA000 431 54 33 and costs £5.28 incl VAT from MB. At least that's how much it cost in July last year when I had to replace mine.
The temperature gauge sender can be bought from the likes of Euro Car Parts or German, French & Swedish, but, if the actual gauge that you require, then you can find a used W124 instrument cluster on ebay and swap over the temperature gauge from it. (ebay Search: "W124 Instrument Cluster" ). They list from about £20 - £30.
Arnie I can't see the information you have kindly posted it seems to across two screens.
