Side strip fixing plugs. Any?
6 replies [Last post]
One of my side strip fixings has popped out.  Does anyone have a couple of actual spares they can post me?
I assume it is just a plastic plug in the metal door hole, and a screw.  So I could just use DIY rawl plugs, but if you have the actual part, happy to buy a beer etc.  Also-- should I drill out the old screw/plug, or try to pull it out (that won't work).  Is the hole circular or square?
garwell11
garwell11's picture
Re: Side strip fixing plugs. Any?
Hello.
its a round hole with a square plug..   a trim puller quite effectively gets these out.
they are still available at merc. I can look the part number up for you on epc if you want. Sadly i have none spare.
g
spike1
spike1's picture
If you can enlarge the picture you can see the fixings
Thanks.  I think I have seen what the plugs look like (round hole, square head on the rawl plug).  On mine it looks like the metal socket in the rubber strip has come away (maybe the head of the screw rusted off), and its still screwed into the plug.  I will try twisting that off when it stops raining. The old rawl plug might then be usable in situ with a plain (galvanised) screw.
Not a biggie. But I will post a couple of close ups.
The backing strip to the rubber can get very rusty and "blow". Like the vehicle itself, mine are plastered thick with Waxoyl. (Other treatments are available and everyone seems to swear by their personal choice.) While the rubber sidestrips were off I replaced all the screws with stainless steel fixings - easily available from the cyberworld. Here's hoping that your rain (or dusting of snow?) stops soon. All the best, Nick.
spike1
spike1's picture
What can happen!
garwell11
garwell11's picture
Ive got a spare front wing pair in used good condition if anybody needs them.
