Routine service
I am looking for someone in the Oxfordshire / Gloucestershire area to service our lwb G300 1991?
Does anyone know of a good garage? We have been servicing since new at main dealer but getting a bit feed up with £430 for a fluid change and the attitude of Oxford Mercedes turning there noise up at an old Mercedes.
Hamish
Good Evening
Any garage can service a g wagon
Just tell them what oil you want to put in engine and genuine or non genuine filters and they will sort it and trans if auto depending on what service interval is due
If its a 1991 it will have issues that no garage can help but as for servicing and a check over any good garage will do it
Just be sure you trust their serviceHow many miles has it done
G
You can download a service sheet here for the car
http://lite.servicemercedes.co.uk/pc/pc_start.asp
It will list all the service tasks and you can take this to your chosen garage for them to tick off.
Time for annual service so did a search of the website and came across this which I thought would be perfect but when I go to the servicemercedes site and specify G463 it only comes up with modern variants (G55, G63 and G350) and assumes that I have a model that will tell me whether I am due for an A or B service.
Unfortunately mine pre-dates this (manufactured in 1991). Is there somewhere that will give a sheet or list of what should be attended to (mine has done 105,000 miles)?
here's a list (some of the cosmetics may not apply, and only items in bold for regular service.
Check and/ or replace front brake calipers, discs and pads
Check and/ or replace rear drum slave cylinders, check brakes shoes, drums, adjust, and clean
Check and / or replace brake-hoses (3) with stainless, PTFE, types (available from Goodrich)
Renew brake fluid (DOT 4 plus or 5.1)
Renew power-steering (ATF fluid) and differential-lock fluids (Brake fluid)
Drain and refill auto-transmission fluid, with new filter and sump gasket. (Refill with synthetic fluid)
Check and adjust auto-transmission lever, replace bushing, if worn
Check track-rod ends. Replace if necessary, adjust tracking
Replace front and rear shock-absorbers
Drain engine oil, replace filter, refill with Mobil-1 0W-40 or 10W-50
Drain and refill front and rear differential oil (Castrol EPX 80W-90)
Drain and refill transfer-case oil (Castrol EP-80)
Lubricate prop-shafts (3 prop-shafts, two greasing points each)
Check ignition leads, distributor cap and rotor, replace where worn or damaged
replace spark-plugs.
Install rear parking sensors (Bosch Park-Pilot URF-7)
Install radio with iPod connector
Install Nokia hands-free telephone kit
Check engine coolant hoses and replace at least all main hoses, if signs of deterioration
Drain and refill coolant (G48 type )
Replace engine multi-vee belt
Check radiator condition
Repair sagging engine-hood blanket
Clean engine bay
Steam clean chassis
Apply waxoyl underbody wax
Fix any small tears/ scrapes in the interior trim.
Update indicators to clear-lens types
Replace rear-wheel cover with stainless-steel locking type
Replace font grille with 2010 version (available- needs painting)
Replace side mirrors with integral flasher types, painted silver
Upgrade to MB 18” alloys and tyres
Light-tint rear windows
Paint front and rear bumper in silver
Install side-steps ?
Arnie to the rescue - yet again.
But are all those every year (brake fluid, diff lock fluids, auto trans fluid, transf case oil, spark plugs, engine coolant)?
Many thanks.
Mark
No, not every year.
Brake fluid every 2 years and coolant: every 3 years (if G48 type)
Diff-lock fluid : every 2 years, with brakes-fluid.
Transfer-case and differentials, every 30,000 miles, but with synthetics, you could go longer.
Prop-shafts: every year.
Front steering ball-joints (repack with grease): every 2 or 3 years
Power-steering fluid might as well do every year or every other year as its a small quantity.(There is a washable filter at the bottom of the reservoir) and easy to siphon out and re-fill.
Spark-plugs, depending on type, but every 20,000 - 25,000 miles for standard-fit versions, and similar interval for distributor cap and rotor. The M103 engine can be quite severe on these parts. Platinum/ iridium versions may go to 60,000 miles.
Transmission fluid, every 20,000 miles for the standard, mineral-oil version of Dexron-II or Dexron-III equivalents. However, if you re-fill with a synthetic fluid, you will noticed improved shifts and you can consider it to be good for at least 60,000 miles, if not more. I have used Fuchs 5000 SL and have seen a definite improvement. http://www.fuchslubricants.com/titan-atf-5000-sl
I think I may have an MB service sheet for older vehicles, somewhere. I'll have a look.
(Apart from the engine, the service sheet you have found for the newer G's will still be applicable for many other items)
Thanks for the reply.
It has covered 124000. had the clutch, head and water pump done at main dealer at 90k
I really just want to keep up the service and wanted someone who knows about g to look after it. We do about 5k a year.
Hamish
