Replacement lower rear spring turrets
I know we had had this discussion before but I have forgotten where we actually buy the replacement spring turrets, my nearside rear has been welded and is holding up but its only a matter of time really b4 it gives especially if I go off road. Are Mercedes the best source?
I guess you don't have Forum search without being a GWOA Member? There are many threads about rust on these mounts and advice to fix. Here are some. With the direct link, you should be able to see it.
http://www.gwoa.co.uk/content/dreaded-rust
Some part numbers (seems like MB are not so expensive for these ones):
Console (support for rear spring): A 460 320 20 78
SHOCK MOUNT Part #460-320-16-78
SHOCK MOUNT Part #460-320-17-78
CHANGE-OVER VAL Part #000-800-04-78
BRANCH-OFF FITTING Part #117-078-01-45
Dealers, easiest way, by lower do you mean the dinner plates that sit on the axle?£10?
Or the turrets on the chassis? About £100 each
Ah, I didn't respond earlier because I thought you said Spring mounts.
I recently had my rear upper shock absorber mounts replaced.
Got them from MB main dealer @ £46.04 plus VAT each (they kindly gave me a small discount for asking nicely).
Really nice solid bits of kit - for that price not really worth looking around for something that might not be as good quality.
Not that eay to see when the holder is in place but it's very easy for mud/water to get behind one plate and it rusts/rots from the inside. Mind you, I think mine were the originals so 28 years is not bad going.
Unless it's a vehicle you can't do without it probably makes sense to wait until it goes again and then have new mount welded in. When I ordered they were available from Milton Keynes so only took 2 days to get at my local MB parts department. If one side's gone then definitely worth doing both sides at the same time as the other won't be far behind.
The shock mounts are available top and bottom, as are the spring turrets, most people have to lift the body to get a welding torch in there, tho this is not as difficult as it sounds.
Shock mounts , easy , unfortunately one of mine snapped off, but ride still ok when one broken.
Front or rear bumper? Bet that wasn't cheap.
Also on 2nd gear knob, other just split.
That thread isn't any use sorry, guess we havent covered it too well, and yes I can access old threads, a simple internet search takes you to threads like this one
http://www.gwoa.co.uk/content/rear-suspension-turrets-coil-spring-mount
doesnt answer where to get it so I'll try the dealers
