Rear lights
Hi all hope some of you can help!!
I plugged in a trailer at the weekend and now my rear lights.indicators,reverse and fog lights won't work :(
Fuse is fine front lights and indicators work but park light is not.
Bulbs are ok but no power to the back apart from brake lights and number plate light.
Any help would be much apprecited
Don't know if thats just a coeincedence or not!
Rear earth cluster on left rear chassis leg end to check
Double check all fuses, remove each and gently squeeze the contacts together, prone to expanding and giving just enough contact untila heavy load applied then they earth thru a different circuit
White wiring joint plug between front and rear loom just below battery from memory, have seen a few of these recently with corroded pins as its exposed, so gently remove spade terminals both side and clean up with sand paper etc
That's what weather does - brings out the trailers for all that garden waste!
I did the same. Was fine til I indicated then dash indicated blown trailer indicator (2012 model 463) - rapid green indicator on dash is another sign of this.
Checked it when I got back - all working again. So like Gav says, I suspect a poor earth, or the trailer hookup just a bit oxidised and needs a clean.
Thanks guys
I got it sorted it was the connection beside the battery had come lose my falt to be honest the previous owner cut a wire on the block next to it and used a crimp connector so I soldered it and shrink rapped it and must off moved the other connection lose.
Easy fix but I went through a wiring diagram with a fine tooth comb not a bad thing to scratch up on:)
Thanks again for your thoughts much appreciated.
