rear coil spring chassis mount
4 replies [Last post]
hniblett
hniblett's picture
Hi all,
my rear passenger coil spring has been broken for some time and has now corroded through the spring mount on the chassis, is there a repair patch for this or do i need a complete new mount?
Hagar
Re: rear coil spring chassis mount
I've had mine welded but there are replacement mounts available; this is a common problem but only on that side which is strange
cox.adrian
cox.adrian's picture
 2X  4603202078  console             252  euro  OR 126 euro for 1 incl tax
mgrays
mgrays's picture
Passenger sides always run in the gutter so get wetter and more potholes.. Everything suspension/brakes wise wear quicker on the "gutter side" on every car..
Look at your axle mounts too.. I did them at the same time (and new springs).. The shock mount is not included in that part.. just the bit between the 2 tubes that holds the spring top.. and the shock mounts will likely need a tickle of weld while you are in there.
There have been a few posts on here about doing it with photos.. go search.
cox.adrian
   shock mounts 4603201778  console            60 euro
                4603201678  CONSOLE   60 euro
