Rear axle disc brakes
10 replies [Last post]
Bill Moss
Bill Moss's picture
Ive fitted disc brakes to rear axle of my 280 GE 460, if any one fancies the same I will be glad to advise
Bill Moss
intermax
intermax's picture
Rear disc brakes
Tell us more!
Difficulty?
Cost?
Advantages?
Bill Moss
Bill Moss's picture
Disc Brakes
Biggest benefit is off roading. You don't loose your rear brakes when the water and mud get in, and its easier to vlean after.
Easy job for skilled engineer.
Cost around £1000. excluding labour costs.
RoyG
RoyG's picture
Rear discs conversion
Hi Bill,
What parts did you use (from which model) for the conversion?
or was it an off-the-shelf kit?
How about brake balance now? Is the master cylinder different too?
Interesting conversion for the off-road guys though...
Roy
peter perfect
peter perfect's picture
No advantage, a costly white elephant, stick to drums on back, hardly notice the difference for a £1000. Been there don that.
mortinson
mortinson's picture
Far from trying to pick up a fight.....
MB and SDP engineers decided to fit the G with rear drums because they reckoned that these could hold the car in a 1:1 incline withour resorting to a transmission handbrake as in some LR products.
The cost wasn't an issue back then so I don't see why it should be an advantage, other than those pointed out by Bill which look quite minor to me.
Bill Moss
Bill Moss's picture
I know which is easiest to clean and to replace when worn.
Balance is no problem.
I didnt need to change master but I did upgrade to further improve braking all round.
Hand brake cables had to be modified, the calipers were made in my own workshops and similar to sprinter rears.
If fitted correctly , in the correct position and with the correct size discs. the static and dynamic friction is an improvement more than 35%
All the lates Gs have discs all round!
frank
frank's picture
really depends on what the G is used for: offroad - drums, motorway - discs. So the early G's got drums and the late ones have discs. Unfortunately the advantages of both systems are not available in one. I'll stick with drums for my part :-) (and buy a set of 8.25 XZL for the 1000,-)
cheers - frank
Bill Moss
Bill Moss's picture
Rear Disc Brakes
I have removed the disc brakes from the rear axle of my 280. the disc and caliper are fine, but the hand brake shoes inside the disc clog up off road and cause excesive wear and heat this was causing cavitation of the brake fluid and ultimately brake failure.. Now I know why LR fit transmission parking brakes.
I have converted the rearbrakes back to drum and shoe but have replaced the standard lining with sinteret.
I will in due course fit the disc assy to my 300 tdi for motorway driving.
jwmol
jwmol's picture
Re: Rear Disc Brakes
I did replace my drum rear axle too with an original post '97 disc axle. So far no problems with clogging the parking brake system.
Did your retrofit use the original 463 parts (or Sprinter)?
JW
Bill Moss
Bill Moss's picture
Disc Brakes
SPRINTER
