Problem with the petrol tank breather bentbdystem
Thu, 11/01/2024 - 09:05
Good morning fellow members
Some of you might recall from a previous post that I've been having intermittent problems starting and running my old wagon and I've changed more parts that I care to remember. In any event after many trials and errors I think we've narrowed the problem down to the tank breather vent system/blockages and a couple of sections on the steel pipe need replacing.
Any advice on the breather system (vacuum and vent) would definitively be appreciated and if anyone has a detailed diagram of the actual breather system you could send me that would be awesome so that hopefully I can fix the problem.
My wagon is a 1988 280ge LWB (petrol) with a single rather than a saddle tank.
Thanks guys.
Thu, 11/01/2024 - 22:27
Re: Problem with the petrol tank breather bentbdystem
I'll try to remove... Somehow it's linked to the other one.
Fri, 08/03/2024 - 01:34
#2
I don't think tank breather would be an issue; to prove your point next time on a non start, open the fuel filler cap and check to see if you have start up. My suspicion would be a fuel/fuel pressure issue or even intermittent fuel relay issue. These need professional testing 5o elimitate fault.
