Part Number
I remove a broken lower trim to the cill section on my 1999 G 500 hopeing to find the part number unfortunatly it was nowhere to be found would anyone happen to know the part number? it on the drivers side below the doors
Regards
Freddie
Freddie,
I've given you 6 months of full membership so you can access the 460/463 parts diagrams and properly searcht he GWOA info forum, because it still works.
I will take a look also, but you will know the exact part you need.
-john
OEM Part Numbers for Lower Door Sill Trim (Scuff Plates) on Mercedes-Benz G500 (W463, 1999 Model Year)
The lower door sill trim (also known as scuff plates or entrance rails) for the 1999 Mercedes-Benz G500 (W463 chassis) refers to the protective interior panels at the base of each door opening. These are typically plastic or stainless steel covers that prevent wear from foot traffic. Based on OEM parts catalogs and compatibility data, the standard non-illuminated trim pieces are consistent across early W463 models (1990–2008), including the 1999 G500. Illuminated versions were optional and retrofittable but not standard on 1999 models.
| Position | OEM Part Number | Description | Notes/Compatibility |
| Front Left (Driver Side) | A463 686 15 36 (or 463-686-15-36) | Door sill scuff plate / entrance rail, front left | Fits W463 G500 (1990–2008); black plastic or stainless finish depending on interior spec. Supersedes earlier variants. |
| Front Right (Passenger Side) | A463 686 16 36 (or 463-686-16-36) | Door sill scuff plate / entrance rail, front right | Fits W463 G500 (1990–2008); mirrors front left. |
| Rear Left | A463 686 17 36 (or 463-686-17-36) | Door sill scuff plate / entrance rail, rear left | Fits W463 G500 (1990–2008); for 4-door models. |
| Rear Right | A463 686 18 36 (or 463-686-18-36) | Door sill scuff plate / entrance rail, rear right | Fits W463 G500 (1990–2008); for 4-door models. |
Additional Details:
- Material and Finish: Standard on 1999 G500 is black plastic with optional stainless steel upgrades (e.g., for AMG styling packages). Confirm your vehicle's interior code (e.g., 214 for black MB Tex) for exact match.
- Replacement Notes: These are direct-fit OEM parts. For illuminated LED versions (retrofit), see A463 540 18 13 (electroluminescent panel) or full AMG sets (no specific number, but genuine OEM kits available for all W463 years).
- Availability: Order via official Mercedes-Benz parts retailers (e.g., mbparts.mbusa.com or gwagenparts.com). Prices typically range $50–$150 per piece, depending on finish.
- Installation: Simple clip-in replacement; no special tools required.
If your vehicle has a specific interior option (e.g., leather, wood trim) or if this is for the exterior side sill molding, provide more details for refined matches. For exact verification, use your VIN at a Mercedes dealer.
I found diagrams, but without EPC Part Numbers. A MB Dealer Parts department should be able to see it.
Freddie do you mean the sill tri, on the inside door thresh hold or the outer lower sill trim?
PM me your VIN and I will get you the number
