Noise behind scuttle - sloshing water?
If I've left the truck out in the rain for a few days there is some noise - maybe sloshing water - on driving off. It might be water draining away.
I did find a damp passenger footwell carpet after the car had been standing a month after xmas (there was water under the carpet on the floors - which are not rusty at all), but I've dried this out with a dehumidifier and it seems to not have returned. I am yet to have my sunroof sorted so this could have been the culprit.
What things should I check before going any further?
Remove the interior mats in the foot-wells, so that they can dry out and also you'll be able to see the route of any further ingress.
Check that the drains in front air-intake scuttle, under the bonnet, are not blocked by leaves/ debris. Gently pour in some water and check that it drains. If not, unblock the drains or water will end up in the cabin.
Open the sunroof and with a jug of water, carefully pour it in each of the two front corners of the frame of the opening, It should drain from under the car, near each front wing. If the sunroof drain pipes have rusted away, they will allow water to flow on to the headlining and then down the interior A-pillars and end up in the foot wells. The pipes can be repaired but this involves removal of the headlining for access. A new sunroof frame is £1600, so a repair is more economic than replacement of the whole part. As a temporary measure, seal the opening from the outside with electrical tape all the way around.
Check that the wiper-spindle caps are not cracked, and preferably packed with grease, as the shaft of the wiper spindles is another common ingress point for water.
Check that the polythene membrane, which covers the interior of each door cavity, behind each door card, is intact and properly sealed to the metal edges of the door.
Check the windscreen is properly sealed, both the rubber to the frame and the glass to the rubber.
Thats a tricky one without hearing it
Exhaust free from leaks and manifold leaks???
Its not before oil has got to top end is it
Does it do it if you dont rev it for a few seconds. It will be something simple im sure
Could the noise be coming from behind the passenger side front wing?
Has it been serviced recently? Some oils really upset my engine, tapped wise, older oils no problem
Doesn't do it at idle. Only notice it when you pull off or rev it. Will get a sound recording with bonnet up.
power steering pumps sometimes give the symptoms you say. check that too
Thanks - some good initial points to check out here.
