New to the G Scene
Hello all.
Im new to G wagons and have been dreaming of owning one for year and years, Having owned lots of 4x4's over the years always had gone Japanese and its worth noting never a land rover of any sort, anyway 2 weeks ago I treated my self to a G Wagon.
The reason for this is because my other 4X4 is/was a 89 landcruser that is used for heavy green laning but with young children I have found next to no time to use it, also because its heavily modded I found it such a worry to use In the road with the children. My Wife and plan to travel for 4 weeks next year towing some sort of vintage caravan, not fully decided where we are going yet, but we plan to fill up with diesel and head off somewhere.
What im looking for is advise on what I need to change and do to keep this OM617A reliable and give it a little more go but not so much power that It goes pop, im sure you know what I mean.
I have been speaking to Diesel Pump UK, and seen what he can do, I find him a very nice honest chap and do plan to have him build me a pump. But im thinking it would be a good idea to buy a bigger radiator beforehand as, who can supply a bigger custom radiator?
Cheers Martin
Welcome Martin.
I love SWB (and have a 230GE) and those wheels are the best :)
There is a lot of searchable material on here - too many forums in fact, going back nearly 20 years of the GWOA 25 years this year. You will get a members pack when we have sourced a nice package.
There are a lot of G veterans passing through here, and there are other forums which are helpful too.
If your 3 litre is a turbo, then thats a solid unit. I have a 463 with OM642, which is the V6 replacement for that - very nice but a lot of electronics in there. There will be experts on here with ideas for your turbo, but there is nothing electronic to really map, so I assume its a case of injectors, turbo, exhaust improvements.
Welcome; I assume you bought a 300GD/ 460 with a turbo conversion; I have no first-hand experience and can only repeat what I have heard in the past: Mercedes never offered the 617A in the 460 but a few years later the 603 in the 350 GD Turbo / G 350 TD (463 with permanent four-wheel drive); it has a slightly higher output than the 617A but had initial problems with the cylinder head and cooling; the solutions for these are known and probably give you pointers for the cooling of the 617A engine as well; it could be worthwhile checking the max allowable torque for your gearbox as well.
Welcome to the G-wagen club, I'd think long and hard before you go down the conversion route, a bells and whistles 606a & looking at a minimum of £10k and needing to chose the best to do the work. Finding a turbo for an old 617 is a different issue entirely as they werent a factory option. Talk to Crewe Engines about your options.
You also have to weigh up the modest decrease in fuel consumption that you might get. The 617 diesel in 3 litre form is slow but utterly reliable, and it will run on anything. The 603 unit in the 463 is a nicer smoother engine very reliable and more powerful [just]. If you intend lots of motorway miles it might be worth doing a conversion but otherwise it doesn't add up. I'd try and sample as many of the different engines the G has to offer b4 you decide. Don't rule out a petrol 463 either, the 103 engines are smooth and fuel efficient, auto will give 18/19 mpg a manual a bit more. The diesel is only 23-25 so after the fuel cost increase barely worth it.
OM617 = 300GD: 87HP, 172 Nm
OM617A = turbo, E Class in Europe: 123HP, 250 Nm @2,400; two (?) Gs were built with this engine on special order in 1982 (?); 280GE: 154HP, 226Nn@4,250; SWB 460 G with 617A could therefore be regarded as ultimate 460.
Hi Martin, have a search through old posts in the forum; I found this one: http://www.gwoa.co.uk/content/617a-whats-difference
I have two friends running 617a engines in 460,s. The engines where from the US and from W126/W123 - S and E class cars. The A means it was built by Mercedes specifically as a turbo unit as opposed to having a tubo fitted to a standard engine. I understand there are a number of differences and the 617A has stronger internals. My experience driving one is it is a great transplant and goes very well and is a straitford job fitting. No idea about upgrades cost v power etc. the two I know of have been reliable and both work for a living!
An unmodified 460 gd will maintain 70mph motorway speeds with no trouble, slower with a caravan but ok
I would have thought a 617A can reach 90 mph. Do you have a 617 or a 617A in your G?
If it is a 617A and it is running hot you might need an oil cooler; but one should first have an understanding why your top speed is too low, i.e. where the power loss comes from.
Here are the offical top speeds:
300GD: 88 HP, 127 km/h = 79 mph
300 GD / G 300 Diesel (463): 113 HP, 141 km/h = 87 mph
350 GD Turbo / G 350 TD: 136 HP, 150 km/h = 93 mph
I think you need an expert here, it might be that your turbo has failed; as a first step I would identify your engine via the engine number and the type of gearbox installed might give clues as well.
I took mine to France, complete with roof box, bikes and 3 passengers, identical car to yours though the diesel pump had been turned up, no problem maintaining 70+. You might try that first
Welcome to the G-wagen club, I'd think long and hard before you go down the conversion route, a bells and whistles 606a & looking at a minimum of £10K
thats a good price, sorry Gordon, I thought it would be a lot more
Pump looks good. Where's that turbo? I would see some of the pump specialists on here and maybe re-furb this pump with bigger/adjusted injectors. Even if you uprate the pump you are not using the extra all the time.
Yes very pleased, not looked at Vin. I do know this engine wasn't in it when it was new, I'm just happy it is what I thought it was. Now I just need to decide on pump choice? Or shal I just twist the current pump further? Looking at the flat head on the top of the pump it's definitely been messed with in the past.
Anyone got the valve clearences measurements to hand?
That sounds like you have info that could make me not want to have one of his pumps?
like I have said reliability is imperative I'd just like a touch more go in a hope that I can keep the truck and caravan to travel at a higher speed so that lorry's arnt over takeing me all day.
