Improve 280GE Drive.
I bought a 280GE back in October...
I am looking to improve the drive of the car
Through my little research online I have found that the best shock absorbers is between Sachs and Koni - Which of the 2 is the better?
Also
Adding 30ml spacers improve the drive I had read too - Is this true!
Any other tips for improving the 280GE!
Also can someone recommend the best brakes manufacturer?
Thank you all in advance.
What's wrong with the drive at the moment?
Has it got big wheels fitted ? The standard 15" rims with big chunky tyres soak up all lumps n bumps. But if someone has pimped it with big rims and elastic band tyres it'll knock your teeth out on gravel !
I replaced my bilsteins with Sachs sportline (£50 ea. online). They seem pretty good quality but they are firm.
You're right buddy ! They are the standard rims n boots ! They should be soaking up the bumps nicely !
Maybe you do need investigate some softer shocks ?
Russ mentioned Monroe. I have those fitted on my 280ge W460 and think the ride is fine. (might be a route to explore)
(I have also driven many many RR's)
Yeh - but I don't think Rolls Royces are that great off road ?
How are things going with your G Wagon, Neil?
Hi Mark,
One day !
I am plodding through many niggles but she's running great now ! My new wiper spindles have been supplied incorrectly. The nipples which the arms attach to differ in position from the one which i removed and has caused no end of grief. I think they have supplied LHD ones.
Once that is sorted i'll be hot on your tail !!!
Neil.
