Heater Alternator
5 replies [Last post]
sbb
sbb's picture
The heater (blower) has given up in my W460 so having to strip out the entire dash to get to the bottom of it.
I've taken enough of the dash out to know that one of two things need replacing:
- Heater Motor.
- Heater Alternator.
From what I can see, I can still buy the motor from Mercedes, but if the alternator is the problem then they do not produce this anymore.
any ideas where I can get hold of one? Old or new?
thanks. SBB.
Re: Heater Alternator
I don't recall what a blower alternator is or where it is located?   But you'd be surprised how may times its a blown fuse.  Check F10 I think it is.  Also does the rear screen heater.
Also the blower switches are known for breaking down... assume your blower is completely dead though?  A new blower is about £170 from MB.   An 'alternator' might be available from someone on here or other G breakers/dealers.
Hmmm... Do I recall that the blower motor from a VW T4 is similar and cheaper? Good luck with the job. It's not especially difficult but it does take a long time. You might think about flushing the heater matrix while you have access.
panzer
panzer's picture
Wise (money saving) advice from Nick 123.
sbb
sbb's picture
Thanks for the advice.
I finally got round to taking the whole dash out to get to it.
The part number is BEHR 92.252.13.117.
You mentioned the T4 motor, would this work as a replacement?
I *think* so. Indeed I am almost certain. Perhaps you could Google/e-bay "VW T4 blower" and compare? From memory I seem to recall that the VW T4 blower motor is a considerably less expensive and direct swap. Red Herring: Back in the day I had a Volvo 121 (Amazon) and it was a glorious motorcar. The fan belt cost a fortune for an impecunious yoof. The Austin Maxi fanbelt was identical and cost relatively buttons.
