Garage around east mids… 2004 g500 starting then dies
3 replies [Last post]
Tee
Tee's picture
Hi guys 2004 g500 lwb lhd had an issue with key so had that reprogrammed so now key turns in lock, good start, then changed springs as previous idiot decided to cut them in half so was bouncing like a mattress in the red light district. HOWEVER NOW runs for a few seconds then dies.
I'm after a garage/ specialist around east mids to look over this issue in particular plus a general check over as newly acquired vehicle.
Any help appreciated.
Re: Garage around east mids… 2004 g500 starting then dies
Hi Tee,
wth. How does a spring get cut down, without the G sinking lower!
Anyway, for garages, I have the following suggestions that came from Mercedes-Benz Club, but no experience with them (look them up):
Autobarn, Northampton.
P Hodge & Sons, Northampton
Rutland Prestige www.rutlandprestigecentre.co.uk
MB Centre, Nottingham, www.mb-centre.co.uk
Haden, Moseley Road, Birmingham
What happened to your old blue G ?
gooch
gooch's picture
Hiya
theres 2x merc specialists near me in hertfordshire that could help I can sling you the info if you want??
1. A 2004 new dash v8 petrol dies after how many seconds?
2. Have you checked the fuel pump in engine bay and under the chassis area ?
3. G400 2001-05 had a similar issue you know was due to cheap ecu chips they bunged in early g's.... it could be the solder points inside the ecu not letting you advance because when the heat up it switches ecu off into fail safe mode maybe
4. Have you had a Star Diagnostic on it?
spike1
spike1's picture
Depending on where you are, try HA Lock, Rushden Northants, Only works on Merc's, very old school 01933 313077
