G463 side steps
38 replies [Last post]
My "new" SWB 463 unfortunately didn't come with side steps/running boards fitted and I think they would help my usual passenger (and me too probably) with entering and exiting.
Am I right - how much difference does having them actually make?
There was a thread some time ago about the merits of fitting real MB parts or those manufactured by another company but I can't find it.
Any comments/suggestions would be greatly appreciated.
Mark
hus55
Re: G463 side steps
Re: G463 side steps
Thanks Huss - but they don't seem to do sidesteps/running boards (what is the correct term?)
Mark
IanA2
IanA2's picture
Re: G463 side steps
MB side steps are pricey. Mine are pretty much the same as the ones on sale on eBay. Definitely make egress/ingress easier.
G-Restorations
G-Restorations's picture
Re: G463 side steps
PM norfolk66  Tim Sayer  he managed to source some that are identical to MB jobbies for reasonable money
Regards Gordon Osgerby
hus55
Re: G463 side steps
that's interesting to know gordon... rgds hus
Norfolk66
Norfolk66's picture
Re: G463 side steps
Mark,
Side steps are all a matter of opinion but in mine they are great for getting in and out with bad footballers knees.....especially getting back in when the game goes into extra time.smiley
I have purchased both the current eBay steps below :-
Ebay item number 390239041010 which were for my SWB....these were very practical and good quality but are not a copy of the originals but good for under £225 including postage.
Ebay item number 221544836175 which are currently on my LWB and are a very high quality copy of exact Mercedes ones. In fact you can't tell the difference side by side the originals and they simply bolt on once you take your grommet caps off your 463! They are from Romania and on at £569 which includes postage. I believe that these are LWB but they may have SWB ones? I can't find my ebay receipt but mine were less that £500 all in and look fantastic. I'm pretty sure I paid £450 plus £45 postage but think the price has slightly gone up because of the £ against the €. But still a great deal.
From the current listing it looks like they only have a single set of LWB which would need to be cut down to fit in yours. (Axel has cut a set down that went on the Jersey 606 monster)
Hope this helps.
Tim
IanA2
IanA2's picture
Re: G463 side steps
Mine are the ones that Tim has listed first. They've been on a good few years now without issue. The MB copies look nicer but not sure there worth the extra money.
Re: G463 side steps
Thanks Ian,
Had a look at those - but the ad says only for models up to 1991 so wondering if that actually means they are for a 460?
http://www.ebay.co.uk/itm/390239041010
If they are for the 463 do all the fittings actually fit (holes line up etc.) or are adjustments needed?
Mark
cox.adrian
cox.adrian's picture
Re: G463 side steps
  MARK  kevin stuttgartt  has rock sliders and they do them with steps
Re: G463 side steps
I tried to purchase an SWB set from MB, last November. Price was around 900, but none available - not even in Germany.
Might be because SWB Gs are no longer in production ?
Re: G463 side steps
Deleted duplicate post
IanA2
IanA2's picture
Re: G463 side steps
Well they fit my 463, mind you it is a 1991. Why not just give him a ring. I guess it's about fitting points which may have changed post '91. Sherlock will know.
IanA2
IanA2's picture
Re: G463 side steps
Duplicate, deleted.
Re: G463 side steps
In case it's still of interest, Gav tells me that the MB ones are now available again - mind you, mucho dinero!
Re the ones that Ian has - contacted the ebay seller to make sue that they would fit my 463 without adapting/making extra holes and reply was :- You will have to drill 2 holes in the outer webbing underneath by the body mount, if they are not there from the factory
Roly
Roly's picture
Re: G463 side steps
Custom fabricated side steps seen a few years ago
Re: G463 side steps
Thank you for the info. Yes, I'd also contacted the sellers on ebay, with a similar reply that new holes would be required. I think those were really designed for the 460, not 463. Anyway, my wife has been asking for sidesteps on her G300 for quite a while, so I will probably need to get them. Only thing is that I am reluctant to remove the new exhaust, catalytic converter and heat-shields that I just fitted, for access to the fitting holes.
Re: G463 side steps
Very nice indeed - looks even better than the OEM ones !
do you still have the design and details of where they were made?
Re: G463 side steps
Have taken the plunge and ordered these ebay versions. I'll report back on how easy/difficult they are to fit. I spoke to Steve at the eBay seller and he assured me that they were "very straightforward".
My budget won out in the end - £212 vs over £1,000 for the real thing.
Roly
Roly's picture
Re: G463 side steps
They are on the G of a member who bought the car with them fitted. She said that the previous owner made them himself.
Design is pretty simple I've got a couple of close up pics if you want them
Roly
Roly's picture
Re: G463 side steps
A couple more photos
Re: G463 side steps
Did they fit properly in the end, with regards to existing mounting holes ? Thinking of getting some too.
thanks
Re: G463 side steps
On my 463 there were NO mounting holes - so that meant drilling 4 each side. If you have to do this you need to get some really hard wearing drill bits (10.5mm) as I went through 3 of them.
But it was all pretty straightforward and I'm glad I did it. They definitely make getting in and out a LOT easier.
If you have mounting holes and want to measure distance between front and back I can measure step and let you know if I think these will work for you.
Don't forget that mine were for a SWB, not sure if he also did them for LWB.
Re: G463 side steps
Thank you for the reply, These would be for a 1991, 300GD. SWB.
Can the L mounting brackets slide along the slots on the underside of the boards, so that their separation can be adjusted to suit the spacing of existing holes, if present?
Re: G463 side steps
Yes they can.
Re: G463 side steps
Thank you for the help.   It should be fine then. Need to see if there are any existing holes there, But I think it will be like yours.
Re: G463 side steps
Hello, Mark,
If you had to drill the holes, presumably it would be difficult to add a backing nut internally? Did you use a Riv-Nut or just large self-tapping screws to secure the brackets?
Re: G463 side steps
Hi Arnie,
The steps come complete with nuts, bolts and washers.
I guess you could fashion a spacer to go inside the struts but they're pretty heavy duty and I didn't (I don't weigh much wink)
If you use a 10.5mm drill bit the bolts are a fairly snug fit.
Re: G463 side steps
Hello, Mark,
Thank you for the reply. The bolts are M10, so a 10.5 mm hole will make a good fit. Perhaps, I am  being a bit thick, but I don't understand how the bolts are fastened with nuts as the place which is drilled is a sealed cavity with no access to the inside to fit the nut?
On the later Gs the nuts are already welded on the inside of the cavity, on the inner side of the bolt hole.
.. Unless of course you drill all the way through the door sill, behind the external rubber strip?
Re: G463 side steps
You need to drill across both sides of the cavity
Will take some close up pics tomorrow which will hopefully reveal all.
Mark
Re: G463 side steps
Ah! I think I understand what you're saying, now.  It seems that these steps are secured to the lateral / transverse underfloor struts, which can be drilled straight-through. That is a 460 step design, then. The 463 is supposed to have ready-prepared holes on the inside door-sills, running longitudinally, under the body, with a captive-nut already welded in the inside. (I have read that even early 463s should have these ready-prepared fixing holes, but don't have access to that car to check before buying the steps.)  That might be why the listing for these steps says they are up to 1990 and that holes need to be drilled to fit them.
Norfolk66
Norfolk66's picture
Re: G463 side steps
Arnie,
I have posted on this thread before as I have installed the cheaper steps on my SWB 463 that were £225 and were a pain in the butt to install. However, you will see from an earlier posting (that went above most heads !) that I had managed to source some exact copies (you can't tell the difference) of LWB 463 steps that were £450 that just needed the grommets removing and bolting on (4 bolts either side for SWB and 6 for LWB) attached are some pictures as this was just a 15 minute job for each sides.The steps although double the price where far superior quality and look. It's all up to personal choice...
Tim
Re: G463 side steps
Hello Norfolk,
Thank you for the reply and pictures. I had indeed noted the replica ones, which you'd mentioned and installed, but I needed to find out whether they could source them in SWB version - no reply. I also saw that 4x4-direct have them, again, LWB versions) for GBP 650.
This enquiry has been for my sister who has a 1991, 300GD and after seeing Mark's post, above, it seemed that early Gs perhaps did not come with factory-built-in mounting points on the inner sill. Therefore she bought the aluminium, eBay ones. However, It could be that these have a different mounting arrangement (designed for the 460) and hence perhaps Mark did not look in the correct place, when he said that there were NO pre-existing fitting points? This would mean, therefore, that it would be better to find 463 boards with the correct brackets, if the mounting points are there, as I'd rather not drill any new holes.
Seems that I  really need to find out first, whether the factory mounting holes are there on not.
I was templed to get the LWB ones and cut them, but they'd need to be cut at an angle and then some new holes drilled to affix the end-caps.
You're right-  yours look  exactly like the factory oines.
thanks.
Re: G463 side steps
All 463's have the proper mount holes already there..
They have grommets fitted and are covered in under seal and are virtually invisible, but there!
If you are looking in the wrong place you will not see them..
Most 460's don't have the holes, however i have seen some late 89 onwards with the correct holes...
With the proper mounts its a dead easy job, without i guess it will be a PITA
Re: G463 side steps
hello, Gav,
That's  good news !
I bought some new, SWB steps from MB this week (ouch !) and fitted them yesterday without problems to my 1996, G300, but wasn't sure about earlier models having the fittings in place. However, if they are there, I guess, worst case would be to buy a set of genuine brackets from MB and use those to fit the eBay, aluminium, steps.
Norfolk66
Norfolk66's picture
Re: G463 side steps
Armie,
I know how expensive the steps were from Mercedes as Gav got some priced up for me a while back.(I think £1100 plus vat per side......double ouch!).
Mine were from Hungary or Romania I'm sure the details are on the eBay link.
If you did want to get a set cut down I know that Axel606 cut a pair of damaged LWB ones for the jersey super G thread that you may be able to search for photos. I believe he may even have a couple of spare original brackets as the SWB only needed 4 in total!
As Gav said the pre-drilled holes should be there as in one of my pictures..However, I had to Stanley knife some of the under seal off to fine them.
They are certainly a lot easier to fit and I had many problems fitting the non Merc ones.
Having said all that both steps do the job and it is just a matter of taste or budget which is preferred.
My steps are great for helping and old footballer get in and out of his G ;-)
Regards
Tim
Re: G463 side steps
Oh dear! Now I feel really silly - fancy having existing mounting holes and not spotting them.
Just had another look and yes they are there. But pretty sure the fitting kit supplied with the ebay version of the steps wouldn't work using the existing holes.
Mark
Re: G463 side steps
Mark
Probably not as not designed too.....they will fit 460 461 and 463 in the same way
Re: G463 side steps
Norfolk66 wrote:
Armie,
My SWB versions were around £ 900 for the pair incl some discount and VAT and so about 300 more than those from direct-4x4, but saved  time in cutting-down long versions to size.
They went on perfectly to the mm, and look great so I  don't regret the amount paid.
