g wagon 463 window motors
My window motors are slow
Its not the wiring or the mechanism its just the motors are tired. Are the motor part numbers bosche 0130821070 and is the other 0130821069
Its the one ending in 69 that i am not sure about. Are these the right numbers and has anyone swapped the motors before
G
Bosch may sell motor separately, MB only sell complete regulator? Think Arnie posted link with a French 4x4 place offering whole thing £180?? But that sounds too cheap
my drivers slow , passenger really good, annoying as sided..
My heated mirrors really toasty, unsure what decides the temperature they switch on? Patrol doesn't have such luxury but heated rear window does work. G one never has....
I thought that switching on the heated rear window also switched on the heated mirrors???
Don't think so? Some sort of thermostat controls them, try putting your hand on mirror glass, when about 5 degrees or below, marvellous hand warmers
I had a similar problem. I don't think the motors run slower because they are tired. It has more to do with the way the glass goes up and down and the associated friction. First thing to check if the glass panel runs true and is not misaligned; also if you need to apply some grease on the moving parts
Hi jason
My drivers was a bit slow but passenger perfectly fine but its not so good now
I have checked voltage and current as my heated mirror also became poor
Its a coincidence i think as window is free and smooth but i have been using it a lot lately so perhaps its getting tired after 26 years of service
The mirror bit is bugging me though. earths and all else is just fine
So my list is getting bigger. Sunroof fails to park. Rear washer does not work. Mirror ns is slow to de frost
drivers window is getting slower. This summer i will sort the lot
