Fuel tank sender
Wed, 13/03/2019 - 12:27
Hi guys, recently on my 2001 G400 my fuel gauge does not go over the first quarter on full tank?
I have checked the sender unit- no gunk very little corrosion which i try to clean as much as i could.
There seems to be no more than. 1 volt coming from the wires.
Should there be a full 12volts on ghe Plus wire?
Has anyone had or know where else i can look for the problem?
Thanks gooch
Wed, 13/03/2019 - 21:20
Re: Fuel tank sender
Did you remove the alloy cover of the sender ? The float can get trapped by diesel gunk
Thu, 14/03/2019 - 21:32
#3
Only familiar with my early 463, but on that if you earth the feed the gauge will read full?
Thu, 14/03/2019 - 21:34
#4
When you say cylinder removed, you did mean you took tube off exposing the float?
Hi thanks for getting back to me! Yes the round cylinder thing i removed. I cleaned all the contacts inside them not a lot of gunk at all. Going to try the fuel pump relay next, maybe theres a bad curcuit in it possibly hence why theres no voltage at the wires ontop of the sender unit.
Will keep you posted
