Fuel accumulator
can a fuel accumulator cause my 230ge to not start ? If so can it be serviced fixed if not does anyone have a working one to sell? Peter perfect sold me my last one. I can be contacted on 07500177180andy
They are sealed cans containing a spring and rubber diaphragm. Not serviceable.
If the diaphragm is perforated, fuel will just take route of least resistance which is straight back to the tank. You can test by plugging the return hose to the tank (on the back of the can). If you require a new one, just buy from your local MB dealer parts dept:
details and part numbers here
or buy from eBay:
(This one even has MB logo on the part number)
I cant quite make that out. Picture is a bit dark.
If the liquid feels oily, then it could either be hydraulic fluid for the rear diff-lock or leaking brake fluid from a rusty brake line. There's not really anything else at the rear of the vehicle.
The picture looks like it's showing part of a small coil-spring and actuation lever which resemble that of the rear brake proportioning valve, in which case you have leaking brake fluid.
Check the brake fluid reservoir and mark a line where the present level is and watch for a day or two.
Thankyou very much have done what you suggested and it fired up straight away , really appreciated , additionally with your wealth of knowledge donyou know what this is? Attached photo , it is at rear of vehicle drivers side and looks to be leaking ????
