Front Seats
I have just butchered my front seat bases as I have fitted the recaros at last SO if anyone wants the old cloth and foams you are welcome to them (TAN LARGE CHECK) they are as worn as most of that age but may be useful for repairs etc. the drivers is the only torn one along the edge where one rolls in and out. I only have one headrest too as i used the other in the middle of the back seat.
Greeney,
How did you solve the problem of the seat bases when fitting your Recaros?
where did you get the recaros? post a pic...
Are your seat foams in good condition????? I may be interested!
Henry G
Looks like I may have to try and mould my own, went to my local MB dealer today to price new ones, they wont sell the foams seperate!!!! you must buy the whole bottom of the seat......wait for it...for £391.00 plus Vat each.......I dont think so!!!!!!!!!!!
The chap I have doing all my body work etc.. says he thinks an MGB seat foam is similar. Ill try that too!!
Cheers anyway
HenryG
Just get an old leather sofa, saw out middle to fit. Add a poufe' and away you go !!! :lol:
Try an electric carving knife (remember those from the 'eighties? :roll: ) to cut "firm" foam to size/shape.
Also - I may be interested in some of the cloth - similar 'roll-out' wear & tear - plus kids - equals some renovation needed!
I removed the trim which is easy as it slots into tracking. Then I cut off the wings that are welded to to the bottom frame and that attach the back squab. this leaves a tubular frame that fitted neatly into the recaro seat frames. I bolted these into place using nylok nuts. The drivers was harder as it has the squab height adjuster on it so I needed to add a bit of extra angle steel to the recaro frame as it held it at a different angle. actually a similar angle to about 3/4 raised up on the adjustment.
The only thing I wasnt over the moon with was the fact my chunky rugby legs now rub the bottom of the steering wheel when I get in and out. but a slightly smaller steering wheel will correct this and that was already on my to buy list. about 3hr job start to finish. I was pleased with the way the original seats just slid off the runners once the stopping screw was removed.
